Master Cylinder and Brake Booster
Old Apr 26, 2008 | 10:04 AM
LSej1's Avatar
Default Master Cylinder and Brake Booster
I am doing a rear disk swap on my EJ1 and i just got my GSR brake booster/ 1" master cylinder in the mail. Now...by the looks of it i have to pull out the dash board in order to get the brake booster off....Is that the case? or can i get to it some other way?
Old Apr 26, 2008 | 12:11 PM
LSej1's Avatar
Default Re: Master Cylinder and Brake Booster (LSej1)
top
Old Apr 26, 2008 | 12:46 PM
phan222001's Avatar
u should be able to acess everything under dash.
Old Apr 26, 2008 | 12:59 PM
SOHC4life 96's Avatar
Default Re: Master Cylinder and Brake Booster (phan222001)
It's 4 bolts underneath the dash and then a pin with a cotter pin holding it in place. Look at the brake pedal and then look up under the dash, there are you bolts and same with the pin.
Old Apr 27, 2008 | 11:16 AM
LSej1's Avatar
Default Re: Master Cylinder and Brake Booster (SOHC4life 96)
Awesome thanks
Old Apr 27, 2008 | 05:30 PM
Mike
Would you please tell me where you got the GSR brake parts from?
I'm looking at replacing my brake booster/cylinder with the same thing but not sure where to buy them from. If you could provide direct links that would be awesome.
Thanks
Mike
Old Apr 29, 2008 | 03:52 AM
LSej1's Avatar
Default Re: Master Cylinder and Brake Booster (Mike"IAMSLOW"Myers)
Ebay for the win Search
AWD: Jeff
Suspension & Brakes
Jul 3, 2010 06:47 AM
gabebauman
Suspension & Brakes
Jul 24, 2009 12:23 PM
MrMug3n
Aug 13, 2008 01:49 PM
mixmastabob
Dec 7, 2006 12:09 PM
Eggman
Oct 6, 2002 09:32 AM
