Help! Could Use A Write Up On Changing My Break Booster.
Having An issue With mine And im Getting Ready To Change The Booster But I Have No Clue What I Need To Be Aware Of For This, Also, I Have An SI Model Delsol And I Do Not Want To Down Grade From My 15/16 i think is what the 4 disc breaks are running off of, Dose this need to corrispond with the booster?
just undo the 2 brake lines under the hood to the master cylinder, then go under the dash and remove the cotterpin thats holding the back of the brake booster to the brake pedal, then theres 4 10mm or 12mm nuts thats holding the brake booster in a square pattern also under the dash, then go up from under the hood again and remove.
Just add in reverse order, bench bleed the master cylinder, and rebleed the whole brake thingy.
Well....you can use this....
https://honda-tech.com/zerothread?id=818263
Just use your eyes and read the parts that are applicable
gabebauman
Suspension & Brakes
07-24-2009 12:23 PM
mixmastabob
12-07-2006 12:09 PM
