What would cause injectors to not work?
Old Jul 12, 2002 | 01:34 PM
EGHatchy's Avatar
Default What would cause injectors to not work?
My injectors are not shooting any gas, what are the things I should check around for? PLEASE help. thanks.
Old Jul 12, 2002 | 01:40 PM
YeuEmMaiMai's Avatar
Default Re: What would cause injectors to not work? (EGHatchy)
1 fuel pressure
ch3ecm fuel pump and fuel pressure regulator
2 faulty ecu or wiring to injectors
3 glogged injectors (I doubt it though since all of them are messed up)
Old Jul 12, 2002 | 02:01 PM
Chiovnidca's Avatar
Default Re: What would cause injectors to not work? (YeuEmMaiMai)
4. Main relay.
5. Fuses.
Old Jul 12, 2002 | 09:24 PM
t's Avatar
t
Get a 9 volt battery and jump the leads on the injector and see if you can hear it click. If it clicks, than the problem is electrical.
Old Jul 13, 2002 | 07:49 AM
EGHatchy's Avatar
Default Re: What would cause injectors to not work? (Teken)
I checked them by taking all the injectors out still connected to the fuel rail, cranked it for about two seconds, and nothing came out...
Old Jul 13, 2002 | 08:02 AM
EGHatchy's Avatar
well, nothing else really...but, I installed my B18 into my Crx about 3 days ago, and I was able to start it up about 4 times, b/t long intervals...
Old Jul 13, 2002 | 10:48 AM
EGHatchy's Avatar
any other ideas?! PLEASE HELP! Im really starting to hate cars...I know that its not the main relay or fuses. And I just put my obd-0 injectors back in with the resistor pack, still didnt work. Please help...
Old Jul 13, 2002 | 10:56 AM
EGHatchy's Avatar
...ok, I just checked my ECU on another LS, and it works, so I can scratch that one out of the list....
Old Jul 13, 2002 | 11:46 AM
EGHatchy's Avatar
yea, I can hear the fuel pump...no, I havnt checked the resistive values(not really sure how too)...
And for the record, this is a 92 Integra LS motor in a 91 Crx SI...I had to make the obd-0 to obd-1 conversion...so there might be some wrong connections on the ECU plugs...what things should I check directly on the ECU plug that would relate to my fuel problem?
Old Jul 13, 2002 | 10:14 PM
fire7882's Avatar
I had the same problem with 3 of my cylinders/injectors. Try this.
https://honda-tech.com/zerothread?id=228485
Old Jul 14, 2002 | 10:59 AM
EGHatchy's Avatar
Default Re: What would cause injectors to not work? (fire7882)
I tried 2 sets of injectors so I dont think they would be clogged...
Old Jul 14, 2002 | 11:05 AM
electrical problem
Old Jul 14, 2002 | 11:25 AM
EGHatchy's Avatar
yea, I think so too...but I dont know where or what to look for to check??? can anyone help?
KillerEG
Jun 29, 2009 08:41 PM
LightningTeg
Jun 6, 2009 05:43 PM
slamedcivic
Nov 2, 2006 01:49 PM
CLE
Jul 13, 2006 02:25 PM
shreddinryguy
Jun 26, 2005 01:28 PM
