Problem with injectors not spitting...
Old Jun 29, 2009 | 09:15 AM
KillerEG's Avatar
Default Problem with injectors not spitting...
ls swapn in a 93 dx coupe..
we pul the fuel rail off and try to turn it over (to see if it shoots out any fuel) and the injectors pop out...we switched em with andother set...and we are getting pressure but no fuel is spitting out?...the dizzy is off but that wont cause it to no spit out fuel right?(we have one on order bc with a good dizzy is still wont fire)
is there a fuse or relay for the fuel injectors?
Old Jun 29, 2009 | 10:03 AM
ek-g6's Avatar
Default Re: Problem with injectors not spitting...
Check to see if you got any power going into the injectors at all.
Old Jun 29, 2009 | 04:34 PM
94 ls-r's Avatar
I do believe the dizzy tells the injectors when to fire. If the dizzy not spinnin it thinks the motor not spinnin. Some one correct me if you know I am wrong. But there is no crank or cam sensor so it runs off the dizzy. Put one on and try
Old Jun 29, 2009 | 07:57 PM
B16R-T's Avatar
there is what is called a cylinder postion sensor in the distributer but without it turning the injectors will not fire there no point in turning it over until you get a distributer
Old Jun 29, 2009 | 08:41 PM
KillerEG's Avatar
k, thanks for the tips, grabn one today!!!
Honda Motorcycles
Feb 13, 2007 08:30 AM
slamedcivic
Nov 2, 2006 02:49 PM
90civSi
Jun 22, 2006 12:23 PM
allmotor.net
Sep 27, 2004 11:57 AM
