Civic engine Q, any help please
Old Apr 25, 2008 | 12:07 AM
Insert-Name's Avatar
Default Civic engine Q, any help please
Well I got a Civic and it had some work done on it, it had a new engine placed in it and has about 50k miles on it and I'm not sure if its a stock D16Z6 still or if the previous owner placed in a different engine. Where's the label, tag, or whatever you want to call it on the engine that says what type it is? I'm new to this so no a$$hole remarks please, I just want to figure out if the previous owner put in a different engine or not.
Also whats are some of the Pros and Cons of switching from the D16 to a B16a if I chose to do that?
Help a newby out please
Old Apr 25, 2008 | 08:27 AM
hatchling37's Avatar
Default Re: Civic engine Q, any help please (Insert-Name)
There's a little flat spot on the front of the block, to the left of the header. It'll have a stamp there with the engine code. D,B,H,F is the series, the next two numbers are the factory engine displacement, and the last letter and number are a classification of that engine. For example, a D16Z6 is a D series, 1.6 liter, Z6.
Pros: B series have almost limitless aftermarket support. More power and torque. Mount kits make them a drop-in affair.
Cons: A little more expensive. A little more complex. Not much else to complain about.
Old Apr 25, 2008 | 05:02 PM
HONDAPARTSMANMIKE's Avatar
Default Re: Civic engine Q, any help please (hatchling37)
x2
zeek1221
Jun 17, 2017 06:22 AM
Un Spun
Jan 23, 2015 06:16 AM
Ozz
May 3, 2005 03:05 AM
