Oil in one intake/head port what's the cause?
Old Apr 24, 2008 | 02:34 PM
Dom_GsR's Avatar
Default Oil in one intake/head port what's the cause?
Hi,
Yesterday, I removed my intake manifold to change it for a new one. I noticed some oil on the left intake port. Also, there was oil in the same head intake port. I put my finger in the port all the way to the valve and I could feel a little pool of oil on the valve. The intake piping was clean/dry so It's not coming from the turbo. What could it be? Valve seal?
Thanks for your help everyone
Old Apr 24, 2008 | 05:59 PM
Boostfed's Avatar
New User
Default Re: Oil in one intake/head port what's the cause? (Dom_GsR)
That was my first guess that it would be the turbo. If it was valve seals I would assume it would be going through the turbo and all too and not reverting back into the intake. Have you actually pulled the pipe from the compressor outlet and checked there? Have you checked the inlet of the turbo also? Does the turbo have a lot of shaft play?
Old Apr 24, 2008 | 07:52 PM
Dom_GsR's Avatar
Default Re: Oil in one intake/head port what's the cause? (Boostfed.com)
The turbo has only 4k miles. The piping from the turbo to the intake manifold is dry and not ''oily'' to the touch so I doubt that the turbo is the cause And there's oil only in 1 port.
Old Apr 25, 2008 | 08:52 AM
Boostfed's Avatar
New User
Valve Stem Seal most likely
Dom_GsR
Apr 25, 2008 07:56 PM
thomas188
Oct 7, 2006 05:28 PM
Regalos420
Aug 2, 2003 04:51 PM
Ri5e
Jan 17, 2003 02:34 PM
Herminator
Dec 18, 2001 07:49 PM
