I need help sanding the bondo..
Old Apr 24, 2008 | 02:16 PM
JDMDC2BOY12's Avatar
Default I need help sanding the bondo..
Sup people so im bout to sanddown the bondo but i dont know sand grit i should use?
after the bondo sanded im going to put a primer, now what sand grit should i use for that? do i wet sand the primer too? thanks for all the help
Old Apr 24, 2008 | 06:08 PM
C-187's Avatar
Default Re: I need help sanding the bondo.. (JDMDC2BOY12)
80 dry for the filler then when you have it almost like you want it 180 then prime
we use 600 wet after priming and youll probly have to do another coat of primer
Old Apr 24, 2008 | 06:16 PM
kiddcarbuff's Avatar
Default Re: I need help sanding the bondo.. (C-187)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C-187 &raquo;</TD></TR><TR><TD CLASS="quote">80 dry for the filler then when you have it almost like you want it 180 then prime
we use 600 wet after priming and youll probly have to do another coat of primer</TD></TR></TABLE>180 then primer? hrm i sue 80, 180 then 320 then prime. lost less of a PITA imo after the primers on to se what you have to block out still
Old Apr 24, 2008 | 06:17 PM
i shoot color after 400 wet usually. as well. i feel that 600 is too fine, esp for a solid color bascoat that is covering the panel well.
Old Apr 24, 2008 | 06:22 PM
C-187's Avatar
Default Re: (kiddcarbuff)
what better is it to go 400 than 600 dude i know uses 800 (its better he says less sand scratches)
just wondering cause im going to school for this
Old Apr 24, 2008 | 06:27 PM
you can use either of the 3. its honestly personal preference. i learned from my father (30+ years of custom bodyowrk and paint) and its what has worked best for him and ahs worked best for me. can i ask what material u are spraying with? dupont basf? ppg? something else?
Old Apr 24, 2008 | 06:33 PM
C-187's Avatar
dupont chroma base and chroma clear
if your doing an all over for hella money do you spray your base ulrta fine then spray another coat of base then clear and cut and buff heard it looks too clean
Old Apr 24, 2008 | 06:43 PM
Default Re: (C-187)
thx for all the help guys
Old Apr 24, 2008 | 06:44 PM
Default Re: (C-187)
thx for all the help guys i will post some pics of my progress
Old Apr 26, 2008 | 10:46 AM
Default Re: (JDMDC2BOY12)
Sup guys so here is the pics i promised
Old Apr 27, 2008 | 05:28 AM
kotic's Avatar
car looks sick bro
Old Apr 27, 2008 | 11:00 AM
Default Re: (kotic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kotic &raquo;</TD></TR><TR><TD CLASS="quote">car looks sick bro </TD></TR></TABLE>thx man.. im bout to shoot it wit primer
Old Apr 27, 2008 | 06:38 PM
hope u sanded using a block and not jsut your hands....
Old Apr 27, 2008 | 06:39 PM
goldex420's Avatar
when u putty starts to have all those spots it means it usally low in there so just give it one smooth fil with ez sand and block it off with 180
Old Apr 28, 2008 | 12:04 AM
2'z kuztoms's Avatar
From: Streets of Sacramento...But now living in So Cal, usa
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kiddcarbuff &raquo;</TD></TR><TR><TD CLASS="quote">hope u sanded using a block and not jsut your hands....</TD></TR></TABLE>
x2
Old Apr 28, 2008 | 05:56 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kiddcarbuff &raquo;</TD></TR><TR><TD CLASS="quote">hope u sanded using a block and not jsut your hands....</TD></TR></TABLE>i didnt use a block for the first two days then finally got one and fnished it everything.. mam, jst realized that doing this ur self is PITA.. but hey gotta try it somehow
Old Apr 28, 2008 | 01:39 PM
FOdoFAsho's Avatar
do this
Old Apr 29, 2008 | 07:22 PM
Default Re: I need help sanding the bondo.. (FOdoFAsho)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOdoFAsho &raquo;</TD></TR><TR><TD CLASS="quote">
do this</TD></TR></TABLE>ohh thank.. Is it ok for me to use the RUSTOLEUM PRIMER CAN from homedepot?
Old Apr 29, 2008 | 07:58 PM
goldex420's Avatar
also on ur quarter panel i can see that its all a huge low spot. u bassicly sanded it all off. it should be one fill ontop of that to really level it out. and get a long board to carve it down.
Old Apr 29, 2008 | 10:36 PM
wholios-EG's Avatar
Default Re: (goldex420)
all so good idea if you use some guide cote
siblues
Paint and Body
Feb 19, 2010 08:15 PM
ek4shizzle
Paint and Body
Dec 7, 2007 01:06 PM
98savage
Paint and Body
May 23, 2007 05:41 PM
slammedcivic22
12
Feb 11, 2004 02:04 PM
