B20B Questions
Old Apr 24, 2008 | 01:31 PM
AGP-EG's Avatar
Default B20B Questions
B20B low compression 8.8
Will the OBD1 PR4 ecu run this motor fine in my car stock without running LEAN
Are these B20B cams the same as B18B1 head cam, because i have a extra set of b18b1 cams if they are actually better then low compression b20b motor cams
Btw i tryed searching google and honda-tech and i can't find sufficient enough info on this swap for it to run like a LS b18 motor EVEN THOUGH it's a 2.0 liter motor.
I also have a FPR incase i need to adjust fuel pressure, let me know if any of you guys ran into anything in particular that you had to do to get it to run just right like a b18 when you swapped b20b motor in, thanks.
Old Apr 24, 2008 | 04:03 PM
AGP-EG's Avatar
Bump, these aren't hard questions people
Old Apr 25, 2008 | 10:21 AM
AGP-EG's Avatar
bump
Old Apr 25, 2008 | 11:41 AM
Jimmy's Avatar
Global Moderator
I believe you could run it and it would be safe, but it might be a little lean due to the b20 using a slightly more amount of fuel..
I'm currently running a Chipped pr-4 on my jdm b20b with a crome pro basemap..
If your ecu was chipped i could send you the .bin file
Old Apr 25, 2008 | 12:11 PM
nytosc's Avatar
From: New York in the summer, South Carolina in the winter
Default Re: (Jimmy)
When mine was stock, I used a P75 ECU from a 94+ integra-
Just use a LS integra ECU that will work-
as for teh cams check out nonvtec.com
Old Apr 25, 2008 | 06:39 PM
AGP-EG's Avatar
thanks for the website.
as for the ecu..i got a obd1 pr4 but some people say the p75 is the same, but idk cause i thought since the p75 is newer it might be a little better perhaps?..lol i guess im just picky.
Old Apr 26, 2008 | 01:50 AM
watsvtecEK's Avatar
Default Re: (AGP-EG)
pr4 worked wonders with my b20. It felt stronger then a "so called" basemap my tuner made on my chipped ecu.
Old Apr 26, 2008 | 06:36 PM
AGP-EG's Avatar
thanks man it seems to work pretty good.
xSteve_Ox
12
Nov 7, 2010 05:31 PM
xSteve_Ox
Engine Management and Tuning
Aug 21, 2010 12:28 PM
boostng r
Nov 6, 2005 05:06 AM
The Stance
Sep 11, 2005 09:31 PM
2SLO
May 9, 2002 01:17 PM
