Name that part...
Old Jul 12, 2002 | 10:17 AM
EGHatchy's Avatar
Default Name that part...
What is number 10 on this diagram???
[img]http://blayzenazn.homestead.com/files/missing.JPG[\img]
Old Jul 12, 2002 | 10:19 AM
EGHatchy's Avatar
Default Re: Name that part... (EGHatchy)
Old Jul 12, 2002 | 10:25 AM
FUP23's Avatar
New User
Map sensor maybe ?
Old Jul 12, 2002 | 10:39 AM
technine's Avatar
Default Re: Name that part... (Devin17)
That's no map sensor since it's bolted to the manifold.
andrew dc's Avatar
IACV
Idle Air control valve.. never mind.. that is 12
fast idle control?
[Modified by CRX25, 7:39 PM 7/12/2002]
Old Jul 12, 2002 | 10:49 AM
DOHCtorJT's Avatar
Default Re: Name that part... (CRX25)
That's a Thermal Thuckle Valve. It controls the temperature of the incoming intake flow and regulates it to acceptable levels for proper fuel mixture and combustion efficiency.
I have no clue really
Old Jul 12, 2002 | 10:50 AM
keithv's Avatar
Default Re: Name that part... (DOHCtorJT)
throttle position sensor?
Old Jul 12, 2002 | 10:55 AM
FUP23's Avatar
New User
Default Re: Name that part... (breaka_1_9)
My bad didnt see it was bolted to the intake...
Old Jul 12, 2002 | 10:58 AM
hahagasdcrx's Avatar
its a purge valve i believe . Its normally located on the firewall with the map sensor and stuff on 88-89 rex's and it switched to the bac of the intakes on 90-91 rex's if you have an older rex si you can match the wires color for color and run extra wire to it .
Old Jul 12, 2002 | 11:42 AM
Mugen Dom's Avatar
Default Re: Name that part... (90crxzcgasd)
its none of that its only on the si its the fast idle selenoid it serves no purpose wut so ever u wont get a code if u dont have it or if it is broken i dont have one on my car at all
Old Jul 12, 2002 | 12:49 PM
Steve91's Avatar
Its either the fast idle valve or the flux capacitor. I'm leaning towards the first
Old Jul 12, 2002 | 01:37 PM
Bleed Black's Avatar
Default Re: Name that part... (Steve91)
Sure its not the map sensor? When I forgot to plug that back in I threw a map sensor code.
Old Jul 12, 2002 | 01:46 PM
rioninja's Avatar
Default Re: Name that part... (jdmB18hatch)
Yeah, Dom is <U>100%</U> correct. It works similar to the IACV, except in a smaller scale. This is the equivilant of the under-the-throttle body coolant temp operated bypass valve that is found on some other models.
Old Jul 12, 2002 | 10:20 PM
oh yeah that too haha
Old Jul 13, 2002 | 09:04 AM
memphiss13's Avatar
its the EVAP purge solenoid valve
Old Jul 13, 2002 | 11:03 AM
rioninja's Avatar
Default Re: Name that part... (rookie2nr)
no, Dom was right. The evap purge valve is on the firewall in this year.
If you look at the hose from it, it goes to directly after the throttle body. It taps directly into the air port that bypasses the throttle plate (same as the IACV).
Like i said, its like an additional mini-IACV.
Old Jul 13, 2002 | 09:26 PM
Home Skillet's Avatar
Default Re: Name that part... (RioNinja)
there should be a honda-tech game show soon. i think it might be on SpeedVision.
deewhite06
Nov 12, 2007 09:52 PM
92civicx
Oct 12, 2007 04:48 PM
FERIOkid
Nov 11, 2006 04:07 PM
mikeunreal
Oct 26, 2005 05:31 PM
