My turbo LS project
This is my project. Will be tuned next week
RLD manifold
Tial 44mm WG
HKS bov
GT3076r .60 .82
Small intercooler (temporary)
Custom IC piping
3" downpipe and cat
Skunk2 70mm exhaust
Stock LS
Let me know what you think
RLD manifold
Tial 44mm WG
HKS bov
GT3076r .60 .82
Custom IC piping
3" downpipe and cat
Skunk2 70mm exhaust
Stock LS
manifold looks great it looks like that ramhorn is much tighter then other companys like its closer to the block cant really tell but good luck what kinda numbers are you looking for ? and please get a dyno graph and post thanks
I don't know how many whp it will do and I will not have dyno sheet cause the tuning will be street tune on .6 bar 8-9lbs.
P.s. sorry for my crappy english I do my best
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraturbo96 »</TD></TR><TR><TD CLASS="quote">I don't know how many whp it will do and I will not have dyno sheet cause the tuning will be street tune on .6 bar 8-9lbs.
P.s. sorry for my crappy english I do my best </TD></TR></TABLE>
turn the boost up more then that
she will last as long as you have a good tuner that 3076 will really start to wake up are you just going to run of wastgate or something ? what are you tuning with ?
yeah its the coolant line because it's not plugged(set up not 100% finished)
my LS burn oil and I will keep the boost low for the moment.My set up is overkill cause its was for a forged motor but money problem. The tuning will be done with chrome pro(I think)
Its a nice setup, but its a little overkill for a stock LS. You're not going to get the benefits of the GT30r on your stock block. You would have made the same power numbers and had comparable spool with something like a T3/T04e 50trim. If you're planning on building the bottom end, then you have a great setup for the future
I have a question guy. My obd0 plug wires for my injectors are inversed. How I suppose to plug them? I have install my resistor box but not the connector cause in not sur the way to plug the wire. My injector are precision. Thanks for your help
chihuahuamanx
Apr 19, 2005 08:14 AM
