royal prurple
Old Apr 21, 2008 | 09:23 AM
Christopherian1982's Avatar
Default royal prurple
How many quarts of fluid does it take for a b16 tranny? And are you suppose to mix half and half of honda mtf with royal purple or i can straight just use royal purple only?
Old Apr 21, 2008 | 09:51 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: royal prurple (Christopherian1982)
Run just the Honda MTF. You dont need the royal purple. What's the point?
IIRC, Honda MTF is Idemitsu synthetic. I know it's def. Idemitsu oil...but I'm also almost positive it's synthetic Idemitsu.
It also has a friction modifier allready in there if you get the Type 2 MTF.
It's a night and day from the old Honda MTF.
2.4qts.
xiongtoua1990's Avatar
just go straight royal purple...and on court i belived it takes 4 courts but buy an extra for sure, because on my gsr it use 4 and a half courts
Old Apr 21, 2008 | 09:53 AM
the point of purple royal is that it help your engine under high stress...so if you do a lot of racing or highway driving then its the best even if you dont it doesnt kill to use them...
B serious's Avatar
Default Re: royal prurple (xiongtoua1990)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xiongtoua1990 &raquo;</TD></TR><TR><TD CLASS="quote">just go straight royal purple...and on court i belived it takes 4 courts but buy an extra for sure, because on my gsr it use 4 and a half courts</TD></TR></TABLE>
No it doesn't. If it did, you over filled it. It's 2.4 qts.
What's your reasoning for royal purple being a better choice?
Old Apr 21, 2008 | 09:54 AM
Relic1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xiongtoua1990 &raquo;</TD></TR><TR><TD CLASS="quote">4 courts but buy an extra for sure, because on my gsr it use 4 and a half courts</TD></TR></TABLE>
engine, yes.... trans no.
trans takes 2.3 quarts.
B serious's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xiongtoua1990 &raquo;</TD></TR><TR><TD CLASS="quote">the point of purple royal is that it help your engine under high stress...so if you do a lot of racing or highway driving then its the best even if you dont it doesnt kill to use them...</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Christopherian1982 &raquo;</TD></TR><TR><TD CLASS="quote">How many quarts of fluid does it take for a b16 tranny? And are you suppose to mix half and half of honda mtf with royal purple or i can straight just use royal purple only?</TD></TR></TABLE>
Old Apr 21, 2008 | 10:00 AM
B serious's Avatar
Default Re: royal prurple (B serious)
BTW, engine oil capacity, is more than 4 qts. It's around 4.5 or so including the filter.
Old Apr 21, 2008 | 03:13 PM
jdmcivicracer89's Avatar
haha the trans only holds 2.3 quarts of oil and honda trans oil is very good.
Old Apr 21, 2008 | 03:15 PM
EG2Driver's Avatar
Default Re: royal prurple (jdmcivicracer89)
there is a reason its called transmission oil and motor oil. There are additives that the two don't share for obvious reasons.
Old Apr 21, 2008 | 04:17 PM
jday1's Avatar
Default Re: royal prurple (EG2Driver)
i have heard some horror stories from people that have used royal purple... I mean bad bad bad stories...
Old Apr 21, 2008 | 04:31 PM
.illwhitecoupe.'s Avatar
Default Re: royal prurple (jday1)
2.3 qts just use the stuff from honda, thats whats its for
nexxxt
Apr 3, 2007 08:48 AM
CPR
Dec 13, 2005 03:40 PM
RAS Motorsports
Oct 10, 2004 12:11 PM
HavokB18
20
May 29, 2003 04:16 PM
bluecrxsi
16
Apr 14, 2003 01:06 PM
