spun rod bearing
Old Apr 21, 2008 | 07:52 AM
boostedeg302's Avatar
Default spun rod bearing
i have a quick question for you guys. it may be obvious but ive never dealt with a spun bearing. im looking to buy some eagle rods for pretty cheap but the guy says that one has a spun bearing. is the rod okay to use if i just replace the bearing with oversized ones or will it just pose problems in the future? again sorry for the noob question but i just wanna make sure before i drop some money on something that i wont be able to use. thanks
Old Apr 21, 2008 | 09:39 AM
Default Re: spun rod bearing (boostedeg302)
Any input would help
Old Apr 21, 2008 | 01:16 PM
90efhatch's Avatar
I would not use them. Eagle rods are pretty cheap to begin with just buy a new set and then you don't have to worry about anything.
Old Apr 25, 2008 | 02:50 PM
vtecb18c's Avatar
i wouldn't go near them. you should never buy a used internal part cause your most likely wasting your money
Old May 23, 2008 | 08:05 AM
FowDow's Avatar
Default Re: spun rod bearing (vtecb18c)
Question if I had a spun bearing in this setup what would be better off... B16 block with ctr pistons in it already, it was a fresh hone, new rings, but I spun a bearing in it and the crank is scared, i only put less then 300 miles on it... what can i do to use this same block and pistons... Parts washer for rings and pistons??? hot tank block then rehone???
http://www.hondamarketplace.co...03753
that has some pics of the walls.. plz help what would be the cheapest way to get my car done
but i want it done right
Old May 25, 2008 | 05:30 PM
vtecb18c's Avatar
Default Re: spun rod bearing (FowDow)
i would make sure that their is nothing else severly wrong and just rebuild it..or sell the whole setup and start from scratch...either way your going to put a nice hole in your pocket...good luck
JDM 98 GSR
K Series
Oct 27, 2011 11:09 PM
LightningTeg
Sep 2, 2011 01:46 PM
boostedeg302
Apr 24, 2008 08:17 AM
boostedeg302
Apr 21, 2008 11:40 AM
ppfalcon
Jun 21, 2005 09:38 PM
