oil pressure issues
Old Apr 20, 2008 | 06:02 AM
vlang29's Avatar
Default oil pressure issues
So i was out abusing the H23vtec yesterday... ran 1st-4th up to about 7400, and now we have fun issues.
at WOT my oil pressure steady. however at cruising or coasting throttle, the psi dips and bounces back irradically 5-20psi...
for example, when at full throttle, it has 50psi at 3k, when cruising or coasting at 3K, it dips to about 30 and bounces back and forth irradically.
Haven't yet checked my gauge sender line, which could be the problem...
has anyone ever heard of this?
Maybe an issue with the oil pump/pickup?
Modified by vlang29 at 1:16 PM 4/20/2008
Old Apr 20, 2008 | 10:09 AM
vlang29's Avatar
Default Re: oil pressure issues (vlang29)
put new sender line on gauge, still same issue.
more car info:
93 BB2
H23A1 block,
H22A head,
255,000 miles
Oil pressure for the last 2 years has been VERY consistent 10psi idle and ~60psi above 4k @ 175* oil temp
Also, when engine drops to idle, it dips to about 400, then catches itself, dips to about 500, then maintains about 700 after a few seconds. And this started exactly at the same time as the oil pressure issues started, so it is not an existing problem.
Vacuum before the "incident" was 22inHg at idle, and now it's more like 19inHg.
this is wierd. The engine isn't making any abnormal noises, power feels normal, VTEC works fine, oil level is at the full line.
also for the last month or two, i noticed another wierd thing with the oil press.. at the SAME RPM, wot registers about 2-4psi higher than closed throttle.
The oil cooler o-ring is seeping lightly, but i couldnt imagine that would be enough to intermittently leak off 10-20 psi
So far my ideas as to the causes:
1. main bearing
2. gasket where strainer bolts to oil pump
3. cracked strainer/pickup tube
any ideas anyone?
Old Apr 20, 2008 | 10:46 AM
98vtec's Avatar
moderator emeritus
you checked cam timing?
take off the oil pan and have a look.
Old Apr 20, 2008 | 12:28 PM
vlang29's Avatar
Default Re: oil pressure issues (98vtec)
update:
there is a 1/4" hole in the screen in the strainer, and a few filings.
Old Apr 20, 2008 | 12:30 PM
98vtec's Avatar
moderator emeritus
wow, wtf did it pick up....? lol
Old Apr 20, 2008 | 03:30 PM
vlang29's Avatar
definately main bearing issue.. closer inspection revealed many filings of bearing in the bottom of the oil pan+strainer.
rip + tear, here we come!
Old Apr 20, 2008 | 08:07 PM
lude98SH's Avatar
vtec solenoid screen ? Idk what strainer your talking about there is only a windage tray down there ?
Old Apr 21, 2008 | 08:09 AM
98vtec's Avatar
moderator emeritus
Default Re: oil pressure issues (lude98SH)
oil pickup has a screen
Old Apr 21, 2008 | 10:23 AM
vlang29's Avatar
i found a good used h22a4 short block in craigs list locally for $300, i'm afraid i'd miss the torque of the h23vtec tho.. so i can't decide.. what do you guys think?
Old Apr 21, 2008 | 10:25 AM
98vtec's Avatar
moderator emeritus
break it down first and see whats going on. I might recommend you getting the main journals align honed.
Old Apr 21, 2008 | 02:36 PM
lude98SH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">oil pickup has a screen</TD></TR></TABLE>
o ok brainfart sorry
TeamSeanFTW
Mar 15, 2011 06:41 PM
JDM_SOHC
Jan 4, 2008 11:48 AM
Xtream_V
Jun 22, 2007 10:05 AM
TurboCX
Aug 3, 2003 06:33 PM
