Axle nut
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondmywrld »</TD></TR><TR><TD CLASS="quote">what size socket do i need to take off the axle nut? i'm trying to get the entire brake knuckle out that's what it's called right?</TD></TR></TABLE>
yes it's called the knuckle (right or left), not the brake knuckle.
as for the socket
, it's been awhile. i want to say 32mm?
as for the socket
It's "technically" called a spindle nut. Depending on what car you have, which wasn't listed in the original post, the nut is usually around 30mm. I must say, trying different size sockets on the nut is probably easier than posting on the forum. Good luck on whatever you are doing.
Modified by mechanix619 at 12:58 PM 4/20/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmoua »</TD></TR><TR><TD CLASS="quote">make sure to use a breaker bar....i usually use the metal jack stick. </TD></TR></TABLE>
I do the exact same thing. Works like a charm.
never fails
never fails
Ah, when I take it off, I just have someone hold down the brakes really hard and start turning. I usually ignore the dent thingy, it's a pain just to get it undented so I just force around it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hanmin »</TD></TR><TR><TD CLASS="quote">Ah, when I take it off, I just have someone hold down the brakes really hard and start turning. I usually ignore the dent thingy, it's a pain just to get it undented so I just force around it.</TD></TR></TABLE>
LOL @ "dent thingy" it's called a stake.
The axle/spindle nut is 32mm, I am 1 million % sure of this, I just did the rear brakes on my EJ6 an hour ago.
thz for the replies guyz, reason i'm asking is because the biggest socket i have is 19mm so i wanted to know which size to buy.
someone mention i can rent it from autozone??? is that for reals? that would save me another 10 bucks
4ghatch
May 27, 2003 08:38 AM
