no oil but vtec?
Old Apr 19, 2008 | 10:35 AM
DoWnfall's Avatar
Default no oil but vtec?
i actually have oil, the title is more of an attention grabber but when i check my oil on the dipstick it never says its higher then the bottom of the dipstick with neither of the holes filled. so i went to change my oil and had exactly 4quarts come out of the motor?
is there a type of clog or common problem any one knows of or a simple solution to fix this?
Old Apr 19, 2008 | 05:00 PM
DoWnfall's Avatar
Default Re: no oil but vtec? (DoWnfall)
bump
Old Apr 19, 2008 | 05:06 PM
z6hatchboy's Avatar
The dip stick goes straight through it holder into the bottom of the motor so i dont see how it could be clogged, but maybe your dipstick for some reason isnt oem and long enough. Also, sometimes if you have new oil it can look as clear as water on the stick because of the sticks color. Is the stick dry, or can you not see the oil?
Old Apr 19, 2008 | 07:29 PM
EG2Driver's Avatar
Default Re: no oil but vtec? (z6hatchboy)
i just did my oil change and put in the exact amount, but my dipstick is reading way above the full line. Go figure...
Get a new dipstick for the motor from Honda, i guess
Old Apr 19, 2008 | 07:44 PM
JDM Lyfestyle's Avatar
Default Re: no oil but vtec? (EG2Driver)
when did you check the oil?right after you ran the engine or after sitting for awhile? if the engine has just been running then oil will be all over the stick.
you could try looking through a junkyard for the same motor and check out the dipstick see if its different before you go buy a new dipstick for no reason
Old Apr 22, 2008 | 06:17 AM
DoWnfall's Avatar
ive been checkin it every night for the past 2-3 weeks when i found this out but im also pretty sure its the oem dipstick to begin with it used to read correctly
Old Apr 22, 2008 | 07:52 AM
shortlid's Avatar
Civic Dipsticks are real hard to seat all the way down. I acutaly bought a new one thinking it was the wrong dipstick and it was the same. If you want it PM me.
Old Apr 23, 2008 | 06:42 PM
DoWnfall's Avatar
Default Re: no oil but vtec? (shortlid)
the motors from a teg so idk if dual cam sticks are the same as sohc
Old May 10, 2008 | 12:26 AM
MIsterE533's Avatar
dohc dipsticks are longer, deeper oil pans. they need more oil. d15-16 take 3.5 b series take 4-4.5.
Old May 10, 2008 | 04:55 PM
wondersparrow's Avatar
mu last engine did the same. it liked to drink oil. the vtec would still kick in with low oil - to a point. that point was beyond the end of my dipstick. eventually the vtec will stop working. keep an eye on it though, I spun a bearing when vtec kicked in and I was low on oil.
jizzer671
Apr 23, 2007 05:58 PM
G2_Fella
Aug 19, 2006 01:40 AM
20_00_lude
Apr 12, 2006 10:08 AM
EKcivic1230
May 31, 2005 06:23 PM
KCLude01
Oct 13, 2003 01:27 PM
