96-00 civic steering rack replacement
im tryin replace my steering rack in my 96 coupe since mine is all messed up and i wonder if anybody knows how or were can i get a diagram or something
really just need to know if i have to drop the cross member or not
i tried searching and found nothing but then again i suck at searching
download the repair manual @ hondahookup.com or check in the haynes repair manual.
i had to replace the steering rack in my 96 coupe, it was a pain.
i had to drop the subframe and all that stuff underneath. you WILL NEED an alignment after everything is complete.
i tried my best not to mess up the alignment, but it was impossible. once i installed my new rack, my alignment was wayyyy out of wack, so i got it aligned the next day and it was all good....
thanks man pretty much all i needed to know is if i had to drop the subframe or not wich look like i do. maybe doin this on the lift will make it a lil easier
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrturbo-ek »</TD></TR><TR><TD CLASS="quote">thanks man pretty much all i needed to know is if i had to drop the subframe or not wich look like i do. maybe doin this on the lift will make it a lil easier</TD></TR></TABLE>
a lift will HELP ALOT. i did my all on the ground, i had the car jacked up and supported on jackstands. a lift will make it so much easier and much more spacious.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MeanGreenMachine »</TD></TR><TR><TD CLASS="quote">
hopefully guess ill fin out next week
</TD></TR></TABLE>hopefully guess ill fin out next week
91RioRedHatchy
Jan 9, 2016 05:16 AM
lordbucanero
11
Feb 19, 2013 02:42 PM
dbailey
Jun 20, 2007 11:12 AM
