EK Front Subframe
EK Front Subframe
I need to replace my subframe. Aside from rust spots, one of the threads for my LCA bolt is damaged. My question is, are all 96-00 subframes the same? I ask because I'm most likely going to be pulling from a junkyard. I have a 96 ex coupe. And is there any recommended maintenance while doing this swap? I know it'll free up a lot of working room once it's out. I already plan on putting in a manual steering rack.
Re: EK Front Subframe
I know the power steering racks are different. One has a bunch of power steering lines, and one is very basic. Unless, you're referring to the subframe when you say rack. and what is IIRC? Lastly, if I will need a certain subframe for use with a manual steering rack, which one? I wasn't sure if they made EKs without power steering.
Ok. Well I'm simply trying to find out if I need a certain subframe, or will any fit just fine from 96-00 in my 96 ex coupe. Forget about the racks and anything else.
The Grumpiest
Could you not have at least TRIED to search for this information since you started this thread?
https://honda-tech.com/honda-civic-d...hatch-2844338/
stiffinEK
20
05-12-2009 11:02 PM
dELfONiK
03-09-2007 12:14 PM
