please help a real eg6
Old Apr 18, 2008 | 06:03 AM
therealeg6's Avatar
Default please help a real eg6
hey this is my first post on honda-tech but ive been reading and researching on this forum for the past year . anyways first of all my car is a 1992 eg6 hatch from japan and it comes with a b16a2 and it seemed to be in top shape ... i know my way around the eg hatches , this one is my third but its my first vtec engine and well my car broke down yesterday . yesterday morning the car started making a tiny grinding noise almost like the starter was stuck or somethjing like that not too loud a sound ...enyways didnt think much of it and after warming the car up and just cruzing i decided to hit a little vtec .. i took off from a stop sign in first gear and slowly climbed up the rps to 5900 then hit the gaz and after half a second of vtec the car sputerded and the engine stoped i costed to a parking lot ....tried to start her again ....no luck .. when i got her home removed the valve cover evrything seemed intact like the valves and timing belt .... so im just wondering what u guys my think is the problem ...the mods i have a skunk 2 pro intake manifold -password jdm carbon intake and apexi n1 cat back thanks for your help guys
Old Apr 18, 2008 | 08:42 AM
BlueIntegraBoy's Avatar
Default Re: please help a real eg6 (therealeg6)
Something like this happened in my friend's car. One of his spark plug's insulator cracked. I'm not sure if you have the same problem.
Old Apr 18, 2008 | 10:00 AM
JDM Lyfestyle's Avatar
Default Re: please help a real eg6 (BlueIntegraBoy)
check the basics first..spark, fuel, and compression..take out the spark plugs, and try turning the engine over with a wrench on the crank pulley and listen for sounds and resistance
Old Apr 18, 2008 | 11:04 AM
roycivic92's Avatar
gas pump?
Old Apr 19, 2008 | 06:12 AM
therealeg6's Avatar
tx guys il do a compression test today and look at my pistons with a flashlight ... cheq spark plugs etc eny other ideas ?
Old Apr 19, 2008 | 11:53 AM
therealeg6's Avatar
hey so i changed my fuel filter ...changed my dspark plugs and checked the spark there all good and checked compresion i have 180 on all cylinders eny ideas
Old Apr 19, 2008 | 12:03 PM
therealeg6's Avatar
Default Re: (therealeg6)
crank position sensor ???
Old Apr 24, 2008 | 08:27 AM
therealeg6's Avatar
bump
Old Apr 24, 2008 | 09:03 AM
Crazydave's Avatar
are you sure the starter aint stuck?
Old Apr 24, 2008 | 09:08 AM
lilo_goki's Avatar
check ur starter as well. does it still crank?
Old Apr 25, 2008 | 11:52 AM
therealeg6's Avatar
Default Re: (lilo_goki)
still cranks perfectly
Old Apr 25, 2008 | 11:18 PM
HondaGuy951's Avatar
wow u got me stumped......hmm.....how are your cams?? wow.....i dunno....i'd like to know what happened too! LoL
Old Apr 26, 2008 | 06:21 AM
davefromPA's Avatar
Default Re: please help a real eg6 (HondaGuy951)
pull off oil pan? spun bearing? something in the bottom end it sounds like
Old Apr 26, 2008 | 10:02 AM
jday1's Avatar
Default Re: please help a real eg6 (davefromPA)
drain the oil and check for metal in the oil... that will let you know if any bearings were chewed up in the motor
umskittles
Jun 3, 2012 11:51 AM
atarigamer01
Jan 11, 2008 07:52 AM
HondaInteg95
Jun 15, 2006 08:02 PM
FullEffect256
Aug 8, 2005 05:27 PM
flydelsolsi
Jun 19, 2003 10:06 AM
