help removing paint residue from garage
Old Apr 17, 2008 | 08:37 PM
PHILEE's Avatar
Default help removing paint residue from garage
Modified by PHILEE at 11:54 PM 5/20/2008
Old Apr 17, 2008 | 09:06 PM
PHILEE's Avatar
help!
Old Apr 17, 2008 | 09:44 PM
ejoner's Avatar
Default Re: (PHILEE)
Rubbing compound/polishing compound/wax.
Old Apr 17, 2008 | 09:48 PM
PHILEE's Avatar
i used this Nufinish scratch remover and i tried clay and wax doesnt help
Old Apr 17, 2008 | 10:37 PM
PHILEE's Avatar
any other tip?
Old Apr 18, 2008 | 01:55 AM
alltech.magoo's Avatar
you can try a light wetsand and buff.
Old Apr 18, 2008 | 02:56 AM
Disease's Avatar
Default Re: help removing paint residue from garage (PHILEE)
Scratch remover is not rubbing compound. Use a rubbing compound and some elbow greese and it will come out.
Old Apr 18, 2008 | 03:14 PM
Rbehne2's Avatar
Default Re: help removing paint residue from garage (Disease)
Grab a bottle of Lacquer Thinner. put a small amount on a rag, rub the surface. Quickly use another rag to re-wipe the surface. It should be gone after doing this the first time.
If not, go through the steps a second time.
Try to do it in the shade, and once you're done, use that rubbing compound to bring the shine back. (Using lacquer thinner may turn the area a little white if you don't rub it clean fast enough.)
Oh yeah, Never use this technique on a freshly painted surface, as this stuff removes fresh over spray.
Old Apr 18, 2008 | 08:51 PM
EkFG's Avatar
Default Re: help removing paint residue from garage (Rbehne2)
Turtle wax rubbing compound its in a plastic container and the **** looks like a red brown
its like 3.00 works great
Old Apr 20, 2008 | 07:04 PM
EGhatch87's Avatar
wet sand with 1500grit...on the white paint be careful no to got to far in to the clear....then use rubbing compound
Old Apr 20, 2008 | 08:46 PM
RoadRage212's Avatar
Default Re: (alltech.magoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alltech.magoo &raquo;</TD></TR><TR><TD CLASS="quote">you can try a light wetsand and buff.</TD></TR></TABLE>
X2 Try buffing it first, though. Always remember to do the least aggressive method first.
Old Apr 21, 2008 | 11:20 PM
dagle's Avatar
Default Re: (RoadRage212)
good tips mentioned above, for me i'd get more info first.
to analyze the damage, grab ur garden hose or a nice bucket of water
pour a steady flow onto the damaged area, if the streaming water on the surface hides the damage, then you haven't really gone passed your clear yet. however, if u see imperfections while a steady flow of water is hitting it, you've got some damage.
clean it real good w/ lacquer thinner or rubbing alcohol or w/e, and then hit it w/ a light rubbing compound. (i wouldn't use the turtle wax stuff tho, that's too aggressive for me) 3M has a decent one. then u step it down slowly w/ polish.. use whatever u can find at ur automotive store.. basically you're looking for a multi-stage polish process that steps it down gradually to a finishing compound. depending on if ur comfortable w/ a buffer or not, there are hand polishes and machine polishes. U start from the more aggressive (higher numbers for the meguiar's stuff) and step it down. so if u had like a lev7 / lev5/ lev3 polish, you would use 7 first, 5next,3after that, and then a finishing polish, then a good couple layers of wax.
Old Apr 25, 2008 | 09:02 PM
2'z kuztoms's Avatar
From: Streets of Sacramento...But now living in So Cal, usa
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rbehne2 &raquo;</TD></TR><TR><TD CLASS="quote">Grab a bottle of Lacquer Thinner. put a small amount on a rag, rub the surface. Quickly use another rag to re-wipe the surface. It should be gone after doing this the first time.
Oh yeah, Never use this technique on a freshly painted surface, as this stuff removes fresh over spray.</TD></TR></TABLE>
Old Apr 25, 2008 | 11:40 PM
PhantoM.DA's Avatar
GDD GRAMMAR POLICE
Default Re: help removing paint residue from garage (2'z kuztoms)
i agree with the thinner, ive used it many times with stuff like that and it works well, the paint was still fine after using it too.
Old Apr 26, 2008 | 05:16 PM
GuNnErGoD's Avatar
Thinner on a rag then wipe with a microfiber. There is no need to immediately wipe it with the microfiber as mentioned previously, though.
shogee
Paint and Body
Aug 11, 2009 09:53 PM
91akira
Detailing
Apr 1, 2009 10:03 AM
WillSB
Paint and Body
Nov 8, 2008 08:36 AM
likeahstone
Paint and Body
Aug 26, 2008 12:18 AM
97CWITR
Paint and Body
Feb 27, 2008 07:20 AM
