Apexi Filter Worth It?
Old Apr 17, 2008 | 01:10 PM
Swerv's Avatar
Default Apexi Filter Worth It?
I was searching around and found a universal filter Apexi offers that will fit my AEM SRI. I found some folks who reviewed this filter on 8th gen Civics, but not much here. Some people had to use a coupler to make it work, but they're advertise as having a 65mm ID. Do these filters not have an actual flange? How do they mount? Has anyone else run this on different intake systems?
Here's a good article:
http://www.mkiv.com/techarticles/filters_test/2/
Old Apr 17, 2008 | 01:12 PM
TrkPlya547's Avatar
Default Re: Apexi Filter Worth It? (Swerv)
Just get an AEM dryflow or a K&N. Unless theyre the same price, then it really doesnt much matter IMO
Old Apr 17, 2008 | 01:18 PM
JoKarma's Avatar
http://mkiv.com/techarticles/filters_test/2/
Reading that alone and locking at the carbon filters is enough to make me want to buy the Apexi Filter.
Old Apr 17, 2008 | 02:13 PM
Swerv's Avatar
Default Re: Apexi Filter Worth It? (JoKarma)
Agreed
Although at the end of the article, it says "if you can trust the original data source...", which was a Japanese article in Revspeed Magazine. Being a Japanese product, of course they want it to be "the best".
They're going for $65 online- not a bad deal if it can be cleaned. I heard soap and water works fine. So who else has any experience with this filter?
Old Apr 17, 2008 | 02:22 PM
JoKarma's Avatar
I've always just washed them out and put them back on when they dried. Never been a problem for me. Especially considering how little you have to worry about that. 30,000 is about two years for the average person.
Old Apr 17, 2008 | 05:01 PM
Swerv's Avatar
So you HAVE used one of these before? I'm confused...
Old Apr 17, 2008 | 07:36 PM
JoKarma's Avatar
Yes. On my EG. On some ebay pipe it worked fine for me. I hadn't researched it before though.
Old Apr 17, 2008 | 10:16 PM
Swerv's Avatar
So does the filter have a flange that slips onto the tube, like a K&N, or did you need an adapter piece? The pics I saw on the 8th gen had the filter bolted to a plate, then coupled to the tube.
edit: upon futher reading, I learned that this was a MAF adapter piece that the filter is mounted to. So my question now is- how can I mount this to the AEM tube? Check out the pic on this site, http://www.frsport.com/APEXi-5....html
There is no flange, like a K&N or the dryflow that I have now.
Modified by Swerv at 11:29 PM 4/17/2008
Old Apr 18, 2008 | 07:43 AM
JoKarma's Avatar
Mine had a hose clamp. I can't tell you much more about it really. Was rebuilding my buddies DSM when he slapped it on. Hose clamp. Cheap tube that I had to weld over a hole on.
Old Apr 21, 2008 | 06:23 PM
Swerv's Avatar
OK, I figured out what I was wrong about.
They make a 65mm filter that uses the MAF adapter to clamp to the intake tube. The FLANGED filters they make are 70mm, 75mm, and 80mm. 80mm would be for a 3" tube. The AEM SRI I have uses a 2.5" tube.
Would a 70mm flanged filter clamp securely to a 2.5" tube? It's about 1/4" larger ID than a 2.5" flange, like the filter the kit comes with.
Dat1BVtecN
Oct 20, 2006 05:48 PM
EK VTi
Feb 21, 2006 03:18 PM
Cone
Sep 5, 2004 07:03 PM
drkblue_civic
Feb 27, 2003 09:04 PM
