Cricket Noise
Old Apr 16, 2008 | 09:45 AM
JaeEK's Avatar
Default Cricket Noise
Im hearing this cricket-type noise whenever the car is running, not sure what it could be?
Post if u got any thoughts
Thanx HT
Old Apr 16, 2008 | 09:56 AM
bubblebrain's Avatar
Default Re: Cricket Noise (JaeEK)
perhaps there is a cricket in your car? lol, jk. i'd say it's the alternator belt. replace if worn/cracked. or just use some belt conditioner if you're lazy!
Old Apr 16, 2008 | 10:04 AM
mercutio_07's Avatar
do you have a mini breather filter on your valve cover vent?
Old Apr 16, 2008 | 04:14 PM
JaeEK's Avatar
Default Re: Cricket Noise (mercutio_07)
No
Old Apr 16, 2008 | 04:28 PM
cherroneballs's Avatar
wheres it comin from? the engine? poss. a heat sheild on the exhaust?
Old Apr 16, 2008 | 04:40 PM
JaeEK's Avatar
Default Re: (cherroneballs)
Yea its from the engine sounded like it was coming from around the pulley area when i checked it.
Old Apr 16, 2008 | 04:48 PM
blade0314's Avatar
Default Re: (JaeEK)
it could also be your throwout bearing in your trannsmission that is if ti a manual
Old Apr 16, 2008 | 06:05 PM
JaeEK's Avatar
Default Re: (blade0314)
im pretty sure its not that cause it made that sound b/f and it was different
Old Apr 16, 2008 | 07:34 PM
Prof007's Avatar
Default Re: (JaeEK)
only while idle? does the pitch change or does the sound go away once engine is reved? does it matter if the engine is cold or hot?
Possible issues could be the AC, Alternator, PS pump, or even the timing belt tensioner.
Old Apr 16, 2008 | 07:43 PM
ls98hatch's Avatar
Default Re: (Prof007)
prof007 is rite most of the time its a alt belt, but just eleviate aggravation change out all the belts cept for timing cause it involves a little work unless it needs one that is
Old Apr 17, 2008 | 06:11 PM
JaeEK's Avatar
Yea its only when idle and the pitch doesn't change at all. Makes the sound no matter what the engine temp is. Mayb it is the alt belt. I wanna c what is b/f i go boost this wkend.
Old Apr 20, 2008 | 08:58 PM
JaeEK's Avatar
checked it and the belt looks fine shows no signs of wear
Old Apr 20, 2008 | 11:11 PM
immajackuup's Avatar
Default Re: (JaeEK)
shoot im having the same problem for about a year.
I just deal with the ekk noise.
Old Apr 20, 2008 | 11:52 PM
batallic's Avatar
check your heatshields i get that sound but when im moving
Old Apr 21, 2008 | 05:51 PM
i fix my problem,my a/c belt was too tight
Old Apr 21, 2008 | 06:36 PM
EkFG's Avatar
Default Re: (immajackuup)
crickets in your engine, lol that was a good one lol
dmanfree
Mar 15, 2013 11:19 AM
looopson
May 26, 2011 10:26 PM
the.hamburglar
Apr 22, 2007 04:52 PM
fangtl
Jan 4, 2005 02:15 PM
