noob question on headers!
Old Apr 15, 2008 | 10:09 PM
I am Ruiz's Avatar
Default noob question on headers!
hey im new here and dont know much about cars
well i got a honda del sol and and had an old d series header laying around.
So i put them on but there is a raspy sound comin from where the headers connect to the cat like theres a hole or somethin. idk what to do haha. sorry for the noob qustion.
Modified by I am Ruiz at 11:14 PM 4/15/2008
Old Apr 15, 2008 | 10:17 PM
unsungfate's Avatar
Default Re: noob question on headers! (I am Ruiz)
first ima assume you have a d series motor in the del sol ue to the fact that the headers fit.
second, rasp is normal with ANY header... due to the increased rate of airflow. if you want to shut it the hell up, get a really good exhaust system or a really good resonator. most people swear by magnaflow... but i got a no name one from a muffler shop alot cheaper than the magna and it worked wonders!
Old Apr 15, 2008 | 10:20 PM
I am Ruiz's Avatar
Default Re: noob question on headers! (unsungfate)
thanks
i was just not sure if it was normal or not
thank you for the info.
Old Apr 15, 2008 | 10:37 PM
obuhmyuh's Avatar
check to make sure its installed properly, ie gaskets installed, and all bolts snugged down... the raspiness can be caused by two metal objects rubbing against one-another...
Old Apr 15, 2008 | 10:44 PM
bmoua's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I am Ruiz &raquo;</TD></TR><TR><TD CLASS="quote">thanks
thank you for the info.</TD></TR></TABLE>
could be that both the headers and your cat is getting too old. Also, could be that your missing the donut(a round metal gasket shaped somewhat like a donut), it sits in between the headers and cat.
Old Apr 15, 2008 | 11:09 PM
I am Ruiz's Avatar
Default Re: noob question on headers! (bmoua)
thanks guys i will check all this out tommorow.
Old Apr 15, 2008 | 11:24 PM
SPD DMN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I am Ruiz &raquo;</TD></TR><TR><TD CLASS="quote">hey im new here and dont know much about cars
Modified by I am Ruiz at 11:14 PM 4/15/2008</TD></TR></TABLE>
Did you wrench the bolts down tight enough? Those bolts WILL come loose if you don't wrank on them hard enough
Is there an exhaust leak somewhere? Did you put the donut gasket back in between the exhaust manifold and cat?
DelSol Dog
19
Sep 28, 2010 05:21 PM
si noob
Dec 10, 2008 12:50 PM
bm3r
Sep 28, 2004 05:18 AM
lucint
20
Feb 7, 2003 08:36 AM
lucint
Feb 5, 2003 06:10 PM
