What might cause the master switch to work one way but not the other?
Old Apr 14, 2008 | 08:36 PM
BlueIntegraBoy's Avatar
Default What might cause the master switch to work one way but not the other?
Actually I have two window switch problems...
1. My passenger window works when the "on/off" lockout switch is switched to "on". It did this with the stock window switch, and with the new switch I put in.
2. On my stock master switch, the passenger window goes down with the switch, but it doesn't go up with it. I had to roll up the pass. side with the pass. switch. I don't have a problem with it now with the new switch, but I'd like to fix the old master switch. I opened it up and the circuit board looks fine. I can't see anything wrong with the switch.
Old Apr 14, 2008 | 10:02 PM
meots98itr's Avatar
Default Re: What might cause the master switch to work one way but not the other? (BlueIntegraBoy)
its the contact point. replace it or do what i did. switch it. im cheap so when i press down it goes up and vise versa.
Old Apr 14, 2008 | 10:23 PM
WickedKP's Avatar
Default Re: What might cause the master switch to work one way but not the other? (meots98itr)
yeap more likely the Contact point in the switch. open up if you can and just use a med. fine sandpaper to clean the points. always worked for me working at a repair shop.
crvpilot
Feb 26, 2018 06:55 AM
xfiles
Nov 20, 2014 05:27 AM
raverx3m
Nov 14, 2014 08:52 AM
builthatch
Honda Civic (2006 - 2015)
May 29, 2012 09:38 AM
ExiledinIN
Apr 19, 2005 05:52 PM
