just installed a gsr swap in my hatch and know have some problems
Old Apr 9, 2008 | 05:11 PM
donvito#1's Avatar
Default just installed a gsr swap in my hatch and know have some problems
fixed
Modified by donvito#1 at 11:14 PM 4/12/2008
Old Apr 9, 2008 | 05:26 PM
lilo_goki's Avatar
tune, ur gonna need it. maybe ur tune sucks, and i suppose u hook up everything right? about ur speed sensor, try replacing it. if it doesn't work still, check ur fuse or either ur alternator is not good. alternator can cause it too, if that still doesn't work, it might be ur plug, ur electrical might not be touching each other(i don't think it can be that though since u have check engine light).
Old Apr 9, 2008 | 05:34 PM
blwn95civic's Avatar
Default Re: (lilo_goki)
If your check ingine light is on with the key turned on the first position then its a wiring issue, if the light comes on when the car is started its a sensor/running issue
Old Apr 9, 2008 | 05:40 PM
Jdm_honda_ek9's Avatar
Default Re: just installed a gsr swap in my hatch and know have some problems (donvito#1)
First, of course the guy you bought it from had no problems with the engine, they never do until you install them.....lol
Second that is the first I've heard about the v-tec being link with the speed-o, only rpm's(I mite be wrong thought)
Third v-tec will not engage if there is no load on the engine (not moving)
as for it dieing, it sound like the MAF sensor or IAC valve(you can clean this one). where did you get the chipped ECU? On ebay they are poorly chipped ECU's plus they are all just copies of fuel maps and v-tec points. To properly tune/chip an ECU it has to be done on the fly as in on a dyno for that individual car. or spend a crazy amount($1,000) for a spoon, mugen, skunk, ect.. tuned not chipped ECU.
I moved to japan a year ago so I got out of the honda seen (cause no one drives honda's here, unless it's a van) so sorry I couldn't be more help.
Old Apr 9, 2008 | 05:47 PM
donvito#1's Avatar
Default Re: just installed a gsr swap in my hatch and know have some problems (Jdm_honda_ek9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jdm_honda_ek9 &raquo;</TD></TR><TR><TD CLASS="quote">First, of course the guy you bought it from had no problems with the engine, they never do until you install them.....lol
</TD></TR></TABLE>no this is the second car i had were their was no speedo no vtec got speedo 2 work got vtec but the ecu came with the swap on the ecu it says russdata never heard of it im might clean out sensors try a stock p72 and get a new speed sensor
Old Apr 9, 2008 | 05:51 PM
donvito#1's Avatar
Default Re: (blwn95civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blwn95civic &raquo;</TD></TR><TR><TD CLASS="quote">If your check ingine light is on with the key turned on the first position then its a wiring issue, if the light comes on when the car is started its a sensor/running issue</TD></TR></TABLE>the weird thind is the cel came on once when drivin and when i went home and shut car down and turn back on the light was off never came back on but i still checked the codes and with no light on it ran the speedo code so idk
Modified by donvito#1 at 11:15 PM 4/12/2008
Old Apr 9, 2008 | 06:10 PM
Skadaloz's Avatar
Default Re: (donvito#1)
thats wat happen to my friends car...runs fine until u WOT it once....we replace the MAP...but i could b wrong...urs might not b the same...so ur MAP sensor might b mess up or TPS is messed up...
Old Apr 9, 2008 | 07:17 PM
donvito#1's Avatar
Default Re: (Skadaloz)
anyone had similar problemswhen i get on it and take it 2 red line it like kinda but not bad sputters untill i let the gas go thenit idles like **** and when i try 2 take off ill give it a little gas and it wants 2 die like bouging down once i turn the car off and turn it back on it runs fine untill i get on it
doitmyself2010
May 24, 2010 12:58 PM
ricearoni56
Feb 11, 2008 05:10 PM
lcjarrett
Feb 18, 2006 11:37 PM
LSracing94
19
Sep 20, 2004 02:04 PM
fukaintmuven
18
Mar 6, 2003 11:17 AM
