Dizzy help
Old Apr 9, 2008 | 03:10 PM
RDAYA0's Avatar
Default Dizzy help
I have a 94 DX Coupe with a D16Z6 in it, my z6 dizzy went out a couple of weeks ago and i popped in a DX/LX dizzy for temp use, is there any way to put the bracket of my old Z6 dizzy onto my DX/LX one? my timing is way off because i can only bolt on 1 out of 3 holes.
Old Apr 9, 2008 | 03:56 PM
GSRcivicDX's Avatar
Default Re: Dizzy help (RDAYA0)
I have a 2000 EK with a 95 GSR swap, I changed all of my dx electronics into the GSR housing so I didnt have to change dizzy plugs. It worked fine, both of the distributors were TEC. If the distributors look the same but just the housing that bolts to the head is different it will probably work, Any one else please chime in if im wrong.
Old Apr 9, 2008 | 04:50 PM
RDAYA0's Avatar
Default Re: Dizzy help (GSRcivicDX)
how hard is it to take replace housings of both dizzys
Old Apr 9, 2008 | 07:36 PM
GSRcivicDX's Avatar
It wasnt very hard. Took maybe an hour max to take both apart, switch the internals and put them both back together.
Old Apr 9, 2008 | 08:28 PM
RDAYA0's Avatar
Default Re: (GSRcivicDX)
damnit wish you lived near me to help me out, im scared i might F*** things up!, but ill give it a shot! DIY ftw
Old Apr 10, 2008 | 10:14 AM
blk92_d16's Avatar
The most difficult thing is probably the rotor screw. If that thing is rusted or won't budge it's a royal PITA!
Old Apr 10, 2008 | 10:16 AM
crx_si-r's Avatar
Default Re: (blk92_d16)
make sure the dizzy screws aren't the ones with the hole and dot in teh middle of them. i forgot wat those are called. ive swapped out plent of em. and thats the only problem i have with them.
Old Apr 10, 2008 | 10:20 AM
RDAYA0's Avatar
Default Re: (crx_si-r)
damnit, i tried taking apart my old busted Z6 dizzy and i [freak]ed it up i threw it in the garbage and just bought a new one, thanks for the help anyways guys!
thesoundofturbo
Jan 17, 2008 09:35 AM
ef9wpb
Oct 10, 2007 06:22 AM
dohdoh420
Oct 30, 2005 05:54 PM
91tegrals
Apr 5, 2005 02:01 PM
91tegrals
Mar 11, 2005 07:18 AM
