Can somebody tell me the length of B series axles for the right and left side
Old Apr 9, 2008 | 12:32 PM
edmek4's Avatar
Default Can somebody tell me the length of B series axles for the right and left side
i need to know the length of each axle driver side and passenger side and also what half shaft they are using
male
or
felmale
Modified by edmek4 at 1:43 PM 4/9/2008
Old Apr 9, 2008 | 12:33 PM
philosofy1's Avatar
Default Re: Can somebody tell me the length of B series axles for the right and left side (edmek4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by edmek4 &raquo;</TD></TR><TR><TD CLASS="quote">I need to know the length of both right and left side and if you are using a female or male half shaft.</TD></TR></TABLE>
?????????????? can you elaborate?
Old Apr 9, 2008 | 12:37 PM
edmek4's Avatar
Default Re: Can somebody tell me the length of B series axles for the right and left side (philosofy1)
edit moved uptop
Modified by edmek4 at 1:42 PM 4/9/2008
Old Apr 9, 2008 | 12:49 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by edmek4 &raquo;</TD></TR><TR><TD CLASS="quote">i need to know the length of each axle driver side and passenger side and also what half shaft they are using
male
or
felmale
Modified by edmek4 at 1:43 PM 4/9/2008</TD></TR></TABLE>
it depends. on the rightside it should all be the same lenth. the leftside is the half shaft and on my b16 it's a male. i've used axles from a 95 del sol (DOHC) and gsr, and both were the same.
here hope this helps: http://www.partsamerica.com/Pr...+Axle
Old Apr 9, 2008 | 12:50 PM
philosofy1's Avatar
i believe the female half shaft are off of 90-93 b-series found in integras.
Old Apr 9, 2008 | 01:04 PM
edmek4's Avatar
thats my problem i have both half shalf that i want to put into my ek with a b18c1 but i dont know which one i should go with. i have 2 axles and none of them have a female side for the male half shaft to go into so what im trying to figure out what length the axles are that ppl are using with each half shaft.
Old Apr 9, 2008 | 01:09 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by edmek4 &raquo;</TD></TR><TR><TD CLASS="quote">thats my problem i have both half shalf that i want to put into my ek with a b18c1 but i dont know which one i should go with. i have 2 axles and none of them have a female side for the male half shaft to go into so what im trying to figure out what length the axles are that ppl are using with each half shaft.</TD></TR></TABLE>
being that you have the axles already i would use the half shaft for those and save the money. just keep in mind that the female axles are on 94-up b-series motors. then reason i say 94-up is those are the axles i have used.
Old Apr 9, 2008 | 01:22 PM
edmek4's Avatar
well also my problem i got the 90-93 half shaft and axle together but i got another axle from a guy that said he had the drivers axle from a 90-93 but that one is half an inch shorter than the one i got with the half shaft so then im guessing it mite be the passenger side axle but im not sure since i dont know the length of anybody elses.
jimep386
May 26, 2007 10:06 AM
DeDonDeRosa
Sep 6, 2006 11:25 PM
Wayne_Curr
Feb 8, 2006 03:05 PM
stivic
18
Sep 6, 2004 12:53 PM
