Can somebody tell me the length of B series axles for the right and left side
i need to know the length of each axle driver side and passenger side and also what half shaft they are using
male
or
felmale
Modified by edmek4 at 1:43 PM 4/9/2008
male
or
felmale
Re: Can somebody tell me the length of B series axles for the right and left side (edmek4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by edmek4 »</TD></TR><TR><TD CLASS="quote">I need to know the length of both right and left side and if you are using a female or male half shaft.</TD></TR></TABLE>
?????????????? can you elaborate?
Re: Can somebody tell me the length of B series axles for the right and left side (philosofy1)
edit moved uptop
Modified by edmek4 at 1:42 PM 4/9/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by edmek4 »</TD></TR><TR><TD CLASS="quote">i need to know the length of each axle driver side and passenger side and also what half shaft they are using
male
or
felmale
Modified by edmek4 at 1:43 PM 4/9/2008</TD></TR></TABLE>
it depends. on the rightside it should all be the same lenth. the leftside is the half shaft and on my b16 it's a male. i've used axles from a 95 del sol (DOHC) and gsr, and both were the same.
here hope this helps: http://www.partsamerica.com/Pr...+Axle
male
or
felmale
i believe the female half shaft are off of 90-93 b-series found in integras.
thats my problem i have both half shalf that i want to put into my ek with a b18c1 but i dont know which one i should go with. i have 2 axles and none of them have a female side for the male half shaft to go into so what im trying to figure out what length the axles are that ppl are using with each half shaft.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by edmek4 »</TD></TR><TR><TD CLASS="quote">thats my problem i have both half shalf that i want to put into my ek with a b18c1 but i dont know which one i should go with. i have 2 axles and none of them have a female side for the male half shaft to go into so what im trying to figure out what length the axles are that ppl are using with each half shaft.</TD></TR></TABLE>
being that you have the axles already i would use the half shaft for those and save the money. just keep in mind that the female axles are on 94-up b-series motors. then reason i say 94-up is those are the axles i have used.
well also my problem i got the 90-93 half shaft and axle together but i got another axle from a guy that said he had the drivers axle from a 90-93 but that one is half an inch shorter than the one i got with the half shaft so then im guessing it mite be the passenger side axle but im not sure since i dont know the length of anybody elses.
Wayne_Curr
02-08-2006 03:05 PM
SuicideSlide
11-20-2004 07:26 AM
