Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
2 piece rotor.
Old Apr 8, 2008 | 12:32 PM
RoadRacer46's Avatar
Default 2 piece rotor.
Does anyone know of a 2 piece rotor that is a direct replacement for the factory rotor?
I don't want to run larger than 15" wheels and I would rather not run adapters brackets for larger than stock rotors.
The car is a 93 civic dx, but I have the parts to run larger integra rotors... if that's my only option.
Thanks in advance,
Patrick
Old Apr 8, 2008 | 02:00 PM
JW racing's Avatar
try fastbrakes.com
Old Apr 8, 2008 | 02:54 PM
Thanks, they do have a direct replacement 2 piece rotor.
Old Apr 8, 2008 | 05:42 PM
6ghatch's Avatar
Default Re: (RoadRacer46)
I used the Fastbrakes 2pc for the past 2 seasons, great bang for the buck. Just get the rotors turned/trued before you use them. For some reason both of my sets had a bad vibration when used new out of the box, but were fine after they were cut.
Here are a couple of pics of the Fastbrakes 2pc with ITR calipers.
For this season I'm trying out the 2pc Stoptech Aero rotors. The main difference being that the Stoptech's are a true 2pc floating rotor and the Fastbrakes 2pc just bolt together.
Modified by 6ghatch at 9:55 PM 4/8/2008
Old Apr 8, 2008 | 06:08 PM
ah ha! a floating rotor is what I am after.
I've run floating 2 piece on my 240 and currently on my Jetta.
Old Apr 8, 2008 | 09:17 PM
Aquafina's Avatar
Excuse my ignorance but whats the difference?
Old Apr 9, 2008 | 04:42 AM
A floating 2 piece rotor will allow for expansion and contraction. It usually has bobbins between the hat and the rotor ring.
A non floating 2 piece rotor has only bolts between the hat and the rotor ring.
Old Apr 10, 2008 | 11:09 AM
kommon_sense's Avatar
Default Re: (Aquafina)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aquafina &raquo;</TD></TR><TR><TD CLASS="quote">Excuse my ignorance but whats the difference?</TD></TR></TABLE>
Makes good sense now that I've read it : http://www.stoptech.com/tech_i...shtml
Old Apr 10, 2008 | 12:08 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RoadRacer46 &raquo;</TD></TR><TR><TD CLASS="quote">
A non floating 2 piece rotor has only bolts between the hat and the rotor ring. </TD></TR></TABLE>
Well, yeah, but on a non-floating 2 piece rotor you also get the pleasure of having 16 (8*2) more bolts going into aluminum just waiting to get threads trashed... plus a bunch of safety-wiring to make sure they don't back out with the thermal expansion/contraction Pain in the ***, and spare hats are expensive!
How quick is a floating rotor rotor-change, if you don't have spare hats or anything? It's about an hour job with the non-floating one. I use a torque wrench on all the bolts now to make sure the threads don't get stripped.
[edit, looking at Stoptech's site, I guess it's pretty similar time?]
Old Apr 12, 2008 | 05:05 PM
ahki's Avatar
Default Re: (Chris F)
Hi guys I run Project-mu SCR-PRO's
will get some pcs for you in the morning.
Old Apr 12, 2008 | 05:44 PM
ginsu2k's Avatar
Default Re: (6ghatch)
How much did you guys pay for the Stoptech Aero rotors? Also, how long do they last, and how easy is it replace a worn rotor? And how much weight did you save over the stock rotor?
Old Apr 13, 2008 | 11:52 AM
ahki's Avatar
Default Re: (ahki)
as promised
it's a bit dirty
Modified by ahki at 12:50 PM 4/17/2008
Old Apr 13, 2008 | 02:03 PM
L8APX's Avatar
Default Re: (ahki)
so can you get the 2 piece prelude rotors "re-drilled" to fit my EG hatch with Prelude calipers?
Old Apr 15, 2008 | 11:41 AM
6ghatch,
Do you have a part number for that stoptech aero rotor? Is that a standard 282mm/25mm rotor? I'm running the ITR front calipers w/redrilled 4x100 '96 prelude vtec rotors. I'd like to get a stoptech aero rotor for my application.
Stoptech told me the part # was 81.057.0111, but when I look in their catalog, I see they are using that same part # for 5 lug applications as well which has me a bit confused.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 6ghatch &raquo;</TD></TR><TR><TD CLASS="quote">
Old Apr 15, 2008 | 12:31 PM
6ghatch's Avatar
Default Re: (kommon_sense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kommon_sense &raquo;</TD></TR><TR><TD CLASS="quote">6ghatch,
I don't have a part number, I just called them and asked for it. I believe it's just the 282/25mm rotor with a 4x100 hat.
Old Apr 16, 2008 | 12:31 PM
EK4civichatch's Avatar
Are there any weight savings compared to the stock rotors?
Old Apr 16, 2008 | 03:53 PM
6ghatch's Avatar
Default Re: (EK4civichatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK4civichatch &raquo;</TD></TR><TR><TD CLASS="quote">Are there any weight savings compared to the stock rotors?</TD></TR></TABLE>
Yes, but I couldn't tell you how much.
Old Apr 16, 2008 | 05:46 PM
Justin Jones's Avatar
I would love to get a 300mm/25mm 2 piece rotor and use a 4x100 hat but it looks like the only ones available are from Project MU and therefore like $750 per pair...
2.7liter
Suspension & Brakes
Mar 5, 2007 02:27 AM
crx1856
Jul 2, 2003 01:11 PM
BryanS
Jun 27, 2002 08:45 PM
95TEG
11
Jun 6, 2002 08:22 PM
sjasmund
11
Jun 1, 2002 06:13 PM
