10:1 compression ratio
i'm probably going to use 10:1 pistons (brother has a set he will give to me for free!) in my 85mm GE Sleeved LS/V turbo build and would like some feedback and possibly dyno graphs for those of you who are running 10:1 c/r. thanks!
I wouldn't be too worried about it. Many people are starting to use higher compression ratios especially for the street. True, you can run as much boost, but you dont need to run as much to make the same amount of power. With sufficient fuel and the right octane rating, you can make a good amount of power and still have good off-boost.
A year ago i made 472whp with 10:1 arias pistons in a 81.5mm gsr block with stock sleeves, ls crank, SC61 20psi and 93 octane. Motor is still in great condition too.
s0liDyNe
Jul 19, 2003 10:24 PM
