ideal compression?
Old Jan 3, 2010 | 10:24 AM
95civhb's Avatar
Default ideal compression?
Doing a z6 build...
was going to do a vitara bottom end, but I'm wondering if I should go with something (SRP's, etc.) with a higher compression...
running a 14b turbo, so I'm wondering if using a higher compression piston would allow more power to be made at a lower psi...
so..
vitara vs higher compression forged?
Old Jan 4, 2010 | 01:09 PM
civic_r87111's Avatar
Default Re: ideal compression?
U hit the nail on the head, higher CR is more power with less psi and better responce. So what do u have in mind for HP?
Old Jan 4, 2010 | 01:49 PM
Unlimited Auto's Avatar
New User
Keep in mind, higher compression plus positive manifold pressure makes more power with less psi, but it also makes a lot more heat at the same psi. Watch your EGT's carefully. Also, you will want to use a relatively low silicone content piston if you want to run high compression and boost. JE for example... Make sure your tune is a little bit on the rich end under boost aswell.
99siRACER
Jan 3, 2012 12:20 AM
slowcrx954
Nov 23, 2006 07:49 AM
99electron_blue_si
Jan 8, 2006 12:41 PM
TehMoonRulz
May 16, 2005 01:15 PM
Slomo_civic
Feb 18, 2004 02:27 PM
