tac welding extended wheel studs into hubs?
Old Jul 10, 2002 | 04:50 PM
reese's Avatar
Default tac welding extended wheel studs into hubs?
is it neccessary to do this? Why or why not? Im using ARP studs.
Old Jul 10, 2002 | 06:35 PM
speedworks's Avatar
Default Re: tac welding extended wheel studs into hubs? (reese)
as long as they pulled into the hub tightly there is no reason
Old Jul 10, 2002 | 06:41 PM
slooowDX's Avatar
i say if you have the welder there when the hubs are out, do it, for added security
Old Jul 11, 2002 | 12:57 AM
ninesecrx's Avatar
Default Re: tac welding extended wheel studs into hubs? (slooowDX)
I wouldnt do it because I makes getting them out way harder if you break one.
Old Jul 11, 2002 | 04:40 AM
Lip's Avatar
Lip
yes do it the first time.
on 2 occassions already with 2 different extended stud brands....they have spun on me. nothing more pain in the *** then trying to remove a lug nut off a spinning stud. just do it..you won't regret it. if you have to remove a broken stud....you have to pull the bearing anyway so its no biggy.
Old Jul 11, 2002 | 04:31 PM
whatVTEC's Avatar
Default Re: tac welding extended wheel studs into hubs? (Lip)
i do think you should tac them. my friend didn't do his and he has two that spin on him. (skunk2)
Old Jul 11, 2002 | 05:01 PM
paulzy's Avatar
Default Re: tac welding extended wheel studs into hubs? (whatVTEC)
if you seat them properly with an impact, they should not spin
Old Jul 11, 2002 | 06:21 PM
Lip's Avatar
Lip
Default Re: tac welding extended wheel studs into hubs? (Slow_ass_4dr)
not true. i had mine pressed with some tonage. its not the seatings..its the actual groves and material. tack them..trust me
Old Jul 11, 2002 | 08:15 PM
mrctr's Avatar
i didnt' have a choice but to tac my arp studs....and it was free.....so it was coo.....even if it wasn't free....i would pay for the welding.....its worth the trouble in the future.....
Old Jul 11, 2002 | 11:46 PM
ninesecrx's Avatar
Default Re: tac welding extended wheel studs into hubs? (mrctr)
by the way, you can change the studs without removing the hub
Old Jul 12, 2002 | 04:58 AM
Lip's Avatar
Lip
Default Re: tac welding extended wheel studs into hubs? (ninesecrx)
this i'd like to see. yes you can with stock length studs by flattening out one side and tapping the old out and doing the same with the new.....but extended studs still hit the hub either way. can't bend them in
Old Jul 12, 2002 | 12:49 PM
reese's Avatar
Ok then im going to weld them in
also should i replace the wheel bearing even if it doesnt go bad when i take the hub off?
Old Jul 12, 2002 | 12:53 PM
sgT's Avatar
sgT
a little modificatoin to the stud and to the hub before hand and it can be done
Old Jul 12, 2002 | 01:02 PM
Lip's Avatar
Lip
Default Re: tac welding extended wheel studs into hubs? (sgT)
have to be real careful i'm sure as to not have balancing issues. i assume your talking about making clearance cuts/drill hole on hub? sounds doable
Old Jul 12, 2002 | 01:28 PM
SilverS's Avatar
care to clarify alittle more??
im expecting my ARP's to show up anyday now..
and dont want to have to press out hte hub like we did last time, that was a HUGE PITA
thanks in advance
Old Jul 12, 2002 | 02:07 PM
sgT's Avatar
sgT
Default Re: tac welding extended wheel studs into hubs? (2000EX)
pretty sure for ARPs you have to remove the hub.
but those have a much lower chance of spinning than the skunk2 studs
Old Jul 12, 2002 | 02:45 PM
paulzy's Avatar
Man I love my hub shark
Old Jul 13, 2002 | 08:50 AM
earl's Avatar
A little bit of creative grinding and you can install longer studs without removing anything. I did it on our crx.
Old Jul 13, 2002 | 11:03 AM
C-speed's Avatar
Default Re: tac welding extended wheel studs into hubs? (earl)
I highly recommend H&R studs.. i've never had a problem with them and i've never had a come-back or customer complain about them.
Old Jul 13, 2002 | 01:18 PM
SilverS's Avatar
what part are you talking about grinding? the hud? the head of the stud?
i'd really not want to grind the head of the stud to a half moon, i dont feel safe.
Old Jul 13, 2002 | 04:21 PM
earl's Avatar
Both, actually. Did a slight grind on the base of the stud and found the best spot on the hub housing to grind a little. You have to be a little creative but also careful. Have gone over 155 mph with no problems yet
If you are not comfortable with this, don't do it but take a look for yourself
Old Jul 14, 2002 | 11:40 AM
SiR831's Avatar
Default i have an extended wheel stud that spins
would tac welding it save it?
Old Jul 14, 2002 | 10:32 PM
khoalie's Avatar
what is a hub shark?
TIA
MadVladCivic
Dec 3, 2015 06:50 AM
marvin75
Apr 24, 2011 05:48 AM
heyimrchills
Jan 3, 2010 05:43 PM
piotrush
Honda Civic (2006 - 2015)
18
Jul 4, 2009 08:31 PM
dynamo
Sep 20, 2002 11:37 AM
