possible to run a Holset hx-35 on a gsr teg with ac?
Old Apr 6, 2008 | 09:58 PM
motormike40's Avatar
Default possible to run a Holset hx-35 on a gsr teg with ac?
I have plans of bolting on some boost on my gsr integra. Is there enough clearence to install a Holset hx-35 a gsr integra and keep ac? That's important when you live in south Georiga.
Old Apr 6, 2008 | 10:14 PM
count me out's Avatar
* B A N N E D *
Default Re: possible to run a Holset hx-35 on a gsr teg with ac? (motormike40)
wow idiot. way to make a thread to answer someone elses question.
Old Apr 7, 2008 | 04:42 AM
Anyone with a productive post?
Old Apr 7, 2008 | 08:33 AM
RCautoworks's Avatar
Default Re: (motormike40)
Can you relocate the a/c lines if needed ? Maybe tweak the condenser a little bit ? Yeah it definitely can be done.
Old Apr 7, 2008 | 08:41 AM
Cool I already have a ac and ps friendly mani, but I know those turbos are pretty large. I just haven't found any photos of them ran on a gsr teg with ac and ps. I'm also going to swap to a half rad and a slim fan.
Old Apr 7, 2008 | 08:59 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by motormike40 &raquo;</TD></TR><TR><TD CLASS="quote">Cool I already have a ac and ps friendly mani, but I know those turbos are pretty large. I just haven't found any photos of them ran on a gsr teg with ac and ps. I'm also going to swap to a half rad and a slim fan. </TD></TR></TABLE>
What manifold do you have ? If you have a cast manifold, its not going to work.
Old Apr 7, 2008 | 09:39 AM
turbo_ls_69's Avatar
Default Re: (RCautoworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RCautoworks &raquo;</TD></TR><TR><TD CLASS="quote">
What manifold do you have ? If you have a cast manifold, its not going to work.</TD></TR></TABLE>
im planning on doing a similar build, what manifold would be the best to fit the holset and ac?
Old Apr 7, 2008 | 12:39 PM
Here's Mine:
Old Apr 7, 2008 | 12:45 PM
93supercoupe's Avatar
id be more concerned of the turbo hitting the block rather than keeping my AC.
I think u got taken buy the seller of that mani....
Old Apr 7, 2008 | 03:56 PM
philafelman's Avatar
Default Re: (93supercoupe)
that wastegate flange placement looks kinda like its a lil too dedicated to the #3 runner as well...
Old Apr 7, 2008 | 08:39 PM
Yea, I was pretty ill about the placement. It looks like it could have easily been centered between all 4 runners.
Old Apr 7, 2008 | 09:55 PM
Default Re: (turbo_ls_69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo_ls_69 &raquo;</TD></TR><TR><TD CLASS="quote">
im planning on doing a similar build, what manifold would be the best to fit the holset and ac?</TD></TR></TABLE>
A custom one, here is one we built for a customer with a holeset, these cast iron ones won't clear cause there not built around holeset turbos. This is a mini ram that the customer still wanted to keep the turbo close to the block but have good oil clearance as well.
Old Apr 17, 2008 | 06:29 PM
Frickr's Avatar
what are the measurements from the block to the turbine outlet on that turbo? i have a HX-35 laying down in my shop, and was wondering if i can fit it between my condensor and block with ample clearence, also is the turbo clockable to get the outlet facing down or at a little better angle? i was thinking about replacing the stock fan on the condenser with a push style to get a little more clearence, but i still dont know if its possible.
Old Apr 17, 2008 | 06:53 PM
Default Re: (Frickr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frickr &raquo;</TD></TR><TR><TD CLASS="quote">
what are the measurements from the block to the turbine outlet on that turbo? i have a HX-35 laying down in my shop, and was wondering if i can fit it between my condensor and block with ample clearence, also is the turbo clockable to get the outlet facing down or at a little better angle? i was thinking about replacing the stock fan on the condenser with a push style to get a little more clearence, but i still dont know if its possible.</TD></TR></TABLE>
NO idea, I sold that about 4 months ago.
rkn527
Aug 21, 2004 12:07 PM
Gfunk176
Apr 15, 2004 11:50 PM
mickey513
Feb 11, 2002 06:30 PM
