Boost Flutter Wastegate Junk? Turbo SOHC
Old Apr 6, 2008 | 09:38 PM
SinglecamMitch's Avatar
Default Boost Flutter Wastegate Junk? Turbo SOHC
I have a cheap xs power wastegate and at full boost 24 psi it will flutter up and down 5 or so psi so i took apart my wastegate and inside the wg the gasket has a small hole that looked melted almost. I am wondering if that would cause me to flutter like that and if so maybe would a nicer tial wg eliminate the problem. I currently have a Big Blue Spring and a Small Blue spring in the wg and am going to get retuned in about a week jw some suggestions. Thanks
Old Apr 7, 2008 | 02:58 PM
bump
Old Apr 7, 2008 | 08:11 PM
Default Re: (SinglecamMitch)
Somebody has to have some clue to if the melted diaphram for sure is the reason to my boost flutter???!!!
Old Apr 7, 2008 | 08:49 PM
RedneckRicer's Avatar
definately a issue. cheap parts with cheap material with a higher failure rate. not to mention a bad reputation. Get a Tial wastegate and your problems will go away.
Old Apr 8, 2008 | 06:34 AM
Default Re: (RedneckRicer)
Thanks for the input but has anybody had the problem before and pinpointed the diaphram to be the source of the problem? ill probably just go by a tial and post my results...more replies please
Old Apr 9, 2008 | 08:57 PM
bump
Old Apr 9, 2008 | 11:50 PM
90dxhmt's Avatar
You always need to inspect the CDM diaphrams prior to install as they are sometimes misalligned etc.Get a Tial diaphram slap it in and all should be good.
Old Apr 10, 2008 | 06:44 AM
thanks im going to pick up the tial tonight thanks for the input ill let ppl know if it fixes the flutter wed when i get tuned
Old Apr 10, 2008 | 02:43 PM
Garage 808 Hatch's Avatar
i have a tial, and its doing the same thing
Old Apr 10, 2008 | 07:35 PM
Default Re: (Garage 808 Hatch)
really damn i just went out and bought a brand new tial wg... how much boost r u running and does it seem like ur dumptube dosent stay open or is it after u hit boost u hear the flutter
Old Apr 10, 2008 | 09:19 PM
im running 27 psi now, it flutters under full boost, anything over 28psi. boost gauge fluctuates back and forth from 25-30psi. it could be tht im just over running the wastegate or the bov though. or could be comp surge
Old Apr 11, 2008 | 06:54 AM
well comp surge is under vac i believe and the flutter im getting sounds like yours at full boost... so u just turned it down till the flutter stopped?
Old Apr 11, 2008 | 05:07 PM
ya, mine is under full boost also. but ya, i turned the boost down a bit, and it helped alot
Old Apr 11, 2008 | 05:14 PM
okay thanks im not putting it on and holding it to the floor until im on the dyno w a wideband but ill let everyone know if the tial upgrade fixed my problem
Old Apr 11, 2008 | 06:46 PM
HiProfile's Avatar
Going from a ebay WG with a torn diaphragm and springs that usually bind in the housing to a fresh TiAl - it should fix most of your boost flucuations. But so might a new diaphragm. SSauto actually sells a thick nomex replacement for ~$15, TiAl sells theres for $50-80 IIRC and should fix.
Old Apr 13, 2008 | 07:29 AM
Thanks for the diaphram info wish i woulda know about that earlier but hey now i can sell my xspower one w/ a tial diaphram in it
Old Apr 21, 2008 | 07:49 AM
Cheap diaphram was the problem now my tial holds great...
Old Apr 21, 2008 | 09:17 AM
TiAL's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Garage 808 Hatch &raquo;</TD></TR><TR><TD CLASS="quote">im running 27 psi now, it flutters under full boost, anything over 28psi. boost gauge fluctuates back and forth from 25-30psi. it could be tht im just over running the wastegate or the bov though. or could be comp surge</TD></TR></TABLE>
what spring? it's probably too weak
Old Apr 21, 2008 | 03:50 PM
Default Re: (TiAL)
1 bar
Old Apr 22, 2008 | 05:18 AM
TiAL's Avatar
yep, get youself a 1.3bar or higher
Old Apr 22, 2008 | 09:15 AM
mike93eh2's Avatar
Default Re: (TiAL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TiAL &raquo;</TD></TR><TR><TD CLASS="quote">yep, get youself a 1.3bar or higher</TD></TR></TABLE>
what size wastegate spring do you suggest using with 24psi and a manual boost controller?
Old Apr 22, 2008 | 10:59 AM
TiAL's Avatar
Default Re: (mike93eh2)
anything over a .9bar
Old Apr 22, 2008 | 02:03 PM
mike93eh2's Avatar
Default Re: (TiAL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TiAL &raquo;</TD></TR><TR><TD CLASS="quote">anything over a .9bar</TD></TR></TABLE>
ok, thats what im running... a large green spring (38mm)
i was just wondering why my boost gauge flutters like crazy when i hit full boost.. the hondata logs show boost holds pretty steady within a few hundredths of psi. i guess maybe just shitty gauge?
Old Apr 22, 2008 | 04:06 PM
Default Re: (TiAL)
its all good, i just ordered a black tial 44mm gate with the springs for ~ 18psi. should be good to go
Old Apr 23, 2008 | 06:28 AM
TiAL's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh2 &raquo;</TD></TR><TR><TD CLASS="quote">
i was just wondering why my boost gauge flutters like crazy when i hit full boost.. the hondata logs show boost holds pretty steady within a few hundredths of psi. i guess maybe just shitty gauge?</TD></TR></TABLE>
probably...or there may be a slight leak in the boost gauge line
DelSolMarine
Apr 17, 2022 10:21 AM
Boosted00
Jan 19, 2018 01:51 PM
alperx
Jan 24, 2012 12:22 PM
crazyimport
Jul 14, 2004 06:08 PM
turbo se
Jun 13, 2003 11:33 AM
