Largest turbo with air conditioning
Hey guys, I have a gsr with a half radiator. Going to get a a/c compatible ramhorn and a kit to reroute the a/c lines.
Wasn't planning on building a block anytime soon but came across a good deal on an extra block so im considering going to a bigger turbo than the 57trim t3/t4 ar 63
Was wondering at what point does the turbo housing become too big to fit between the motor and the condenser? Or should I keep that turbo? Was looking at about 450hp
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CX »</TD></TR><TR><TD CLASS="quote">Your 57 trim will make very close to 450whp, I'd stick with it
True, but at that power it will be severely stressed. Longevity will suffer in the long run, if continued at that maximum level.
</TD></TR></TABLE>True, but at that power it will be severely stressed. Longevity will suffer in the long run, if continued at that maximum level.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan »</TD></TR><TR><TD CLASS="quote"> True, but at that power it will be severely stressed. Longevity will suffer in the long run, if continued at that maximum level.</TD></TR></TABLE>
Good advice, thanks
....so i started looking at the GT30R but will that even fit between the motor and the condenser?
Good advice, thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quiksheit »</TD></TR><TR><TD CLASS="quote">
Good advice, thanks
....so i started looking at the GT30R but will that even fit between the motor and the condenser?</TD></TR></TABLE>
Yes, the compressor side with face the radiator. It makes it hard to route 4" intake but it can be done. You will also have to knotch your block some but its nothing major. I'm using a full-race AC ramhorn manifold.
Good advice, thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by da_dude »</TD></TR><TR><TD CLASS="quote">sc6152e</TD></TR></TABLE>
x2
small, but big. 500whp capable. i run it.
x2
You could also look into a Sidewinder/Hytech style manifold.. Then you wouldn't have any issues with clearance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quiksheit »</TD></TR><TR><TD CLASS="quote"> a kit to reroute the a/c lines.
Were did you find the reroute a kit? and how much?
I think the GT30 is the best turbo for your power goals.
MindEracer- Muckman had a kit to reroute air conditioning lines. He was selling them for about $150 but i think they were only for DC2's
Thanks guys that is pretty good input. As most a/c users know it is hard searching air conditioning since "a/c" cannot be searched. Gonna definitely look into the precision line some more since it does seem a little easier on the pocket (but i guess that whole budgeting thing went out the window a long time ago
CustomX113
Nov 20, 2006 09:27 AM
boostedSI90hatch
Apr 28, 2006 09:01 AM
