thinking of makin a solid steel motor brace. ok or gonna break something?
Old Apr 6, 2008 | 06:06 AM
97grnrs's Avatar
Default thinking of makin a solid steel motor brace. ok or gonna break something?
i already have solid mount inserts but i wanna eliminate any chance of the motor moving during track runs. i was thinkin of fabbing up some kind of rod or brace to bolt on to the block somewhere to stop any movment . the problem is i dont want to have the brace end up smashing through the block or cracking it or anything like that when the motor tries to move a lil. anyone try this ever? good or bad idea? its on a crx single cam turbo, i dont wanna put it on the head cause i fear it will slowly rip the head up from the block ..
Old Apr 6, 2008 | 10:14 AM
NJIN BUILDR's Avatar
Default Re: thinking of makin a solid steel motor brace. ok or gonna break something? (97grnrs)
If you have solid mounts already...your all done.It's not going to move unless the mounts rip out.Anything more is just added weight.
Old Apr 6, 2008 | 12:01 PM
egb16pg's Avatar
pfft yea or shear the mount bolts. lol
Old Apr 6, 2008 | 01:29 PM
97grnrs's Avatar
well it still moves a bit. not much but i want it solid. im still debating if it would help or break something
Old Apr 6, 2008 | 04:01 PM
egb16pg's Avatar
do you have a torque bar?
Old Apr 6, 2008 | 07:07 PM
blinx9900's Avatar
if you wanna limit movement to the fullest go get yourself some solid billet mounts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">If you have solid mounts already...your all done.It's not going to move unless the mounts rip out.Anything more is just added weight.</TD></TR></TABLE>
i dont think he has solid mounts, im guessing he either has the ES inserts or urethane mounts per this:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97grnrs &raquo;</TD></TR><TR><TD CLASS="quote"> i already have solid mount inserts </TD></TR></TABLE>
Old Apr 7, 2008 | 05:03 AM
97grnrs's Avatar
Default Re: thinking of makin a solid steel motor brace. ok or gonna break something? (blinx9900)
do they make them for single cam ?
Old Apr 8, 2008 | 03:26 PM
blinx9900's Avatar
why dont you call hasport/avid/innovative to find out
ProjectEvilEj2
Dec 25, 2012 09:57 AM
spags930
Mar 4, 2010 04:08 PM
O16581724 5 2 5
Oct 1, 2005 05:57 PM
sydag5
Oct 13, 2003 12:00 PM
Muckman
Apr 1, 2003 05:51 AM
