Aluminum motor mounts available anywhere?
So out of frustration of my driver's side motor mount coming loose, i put Loctite on the bolts into the block. My lower bolt came loose, stripped the threads, then snapped the top bolt in the block. I tried an EZ out and the stud will not come out, basically, i want an aluminum mount to replace this that i can simply weld to my block.
Re: Aluminum motor mounts available anywhere? (deadend9009)
I saw that Hasport's are aluminum after posting this, but they're too freakin' expensive. I guess i can try taking the piece to a machine shop and have them try to make something similar.
You mean like it did.
I tried taking the mount apart and i can't get it to unbolt, i kind of need a whole new mount anyway as it was broken and i just filled it with Urethane. I know there's companies other than HASport that makes mounts for Hondas, but i can't find them, a friend of mine bought one with aftermarket mounts that weren't by them. I just need an aluminum driver's side mount.
ProjectEvilEj2
12-25-2012 09:57 AM
cmamtower
10-23-2010 08:53 AM
lsxtreme81
Welding / Fabrication
21
03-22-2010 08:16 PM
PSU-TEG
04-30-2003 08:55 AM
