ABS Light On
Old Apr 5, 2008 | 06:00 PM
JesseBizz's Avatar
Default ABS Light On
Alright so the other day i changed both front brake pads and rotors on my 1996 civic si and when it came to the driver side i had to replace both CV boots on the drive shaft after that we installed everything put the tires on and had the car on axle stands and put the car in gear to hear if everything sounded good so it did than i hit the gas a little bit and the ABS light came on, so i took the tires off took out the sensor and cleaned it and the part of the shaft that it comes into contact did this on both sides and now i'm at a stand still what else could be the problem?
Old Apr 5, 2008 | 06:06 PM
mechanix619's Avatar
Default Re: ABS Light On (JesseBizz)
I'm going to say the obvious I know but check the fuse.
Old Apr 5, 2008 | 06:14 PM
JesseBizz's Avatar
Default Re: ABS Light On (mechanix619)
the abs fuse? where is it located? oh and someone in my family suggested it could be the 'wiring clocket' located behind the steering wheel
Old Apr 5, 2008 | 06:18 PM
slowcivic2k's Avatar
Make sure you didn't damage the tone ring on the outer joint, or the sensor and its harness while removing the driveshaft. They have a habit of failing if you provoke them after its stayed that way for years.
Old Apr 5, 2008 | 06:19 PM
The clock spring/cable reel is located behind the steering wheel. The clock spring is not wired up to your ABS. Just to make sure, it is your ABS light that is on and not your SRS light? A bad cable reel will cause the SRS light to come on, the cruise control and horns to fail.
And the fuse is located under the dash. It should be a 7.5A.
Modified by mechanix619 at 7:51 PM 4/5/2008
Old Apr 5, 2008 | 06:27 PM
JesseBizz's Avatar
no no its the ABS light for sure ill check that fuse probably tomorrow
and where is the tone ring? is it inside the outer CV boot or the ring after the inner cv boot that is in the splines that goes into the tranny?
Old Apr 5, 2008 | 06:30 PM
Default Re: ABS Light On (slowcivic2k)
uhhh the ABS and SRS systems are totally separate, do not mess with the steering column.
its on the outer joint like i just said, outer being furthest away from the center of the car. its a big aluminum ring that looks like a gear stamped onto it.
Old Apr 5, 2008 | 06:32 PM
JesseBizz's Avatar
hmmm well we cleaned all the grease off of it, it didnt look damaged =\
Old Apr 5, 2008 | 06:51 PM
spray_bombed's Avatar
check the wheel speed sensors....they will throw the abs light
Old Apr 5, 2008 | 07:10 PM
JesseBizz's Avatar
Default Re: (spray_bombed)
where exactly is that?
Old Apr 5, 2008 | 07:59 PM
povs9's Avatar
Default Re: (JesseBizz)
i narrowed down which of my abs sensors was bad by checking each resistance. 3 were close and the other was way off
Weez1
Honda CR-V & Element
Jun 18, 2013 04:19 AM
AccordParts
Mar 26, 2012 11:37 AM
H22a T13
Nov 29, 2005 09:44 AM
Rain_man
Aug 28, 2001 04:32 AM
