Mobil Delvac 1300 Super For a Turbo Built Honda?
Old Apr 5, 2008 | 03:28 PM
Quad-Damage's Avatar
Default Mobil Delvac 1300 Super For a Turbo Built Honda?
15W 40 is that two thick? I have been told that it would work well with my built Turbo motor
Would Mobil 1 Turbo Diesel be bad to put in a built turbo motor, I have been told that it's better to put thicker oil, being that i have a oil cooler, and turbo car.
It is marketed for "For gasoline engines only"
Anyone else run this?
http://www.mobil.com/USA-Engli...r.asp
Old Apr 5, 2008 | 03:41 PM
awdgsx96's Avatar
Default Re: Mobil Delvac 1300 Super For a Turbo Built Honda? (Quad-Damage)
My friend's tuner has him use Diesel oil in his built Eclipse. It hasn't had a problem yet, so I guess it's ok to use
Old Apr 5, 2008 | 04:57 PM
Default Re: Mobil Delvac 1300 Super For a Turbo Built Honda? (awdgsx96)
my tunner does as well
Old Apr 5, 2008 | 09:02 PM
2 thick?
Old Apr 5, 2008 | 10:26 PM
quicksilver1689's Avatar
i ♥ snails
shells rotella works good
Old Apr 6, 2008 | 12:37 AM
importdude2000's Avatar
i think 15w40 is perfect after i run outa of my castrol
im going rotella 15w40
8-9 buck per 4qt not bad
im too cheap to buy 5w50 royal purple
higher hot velocity is better for the turbo
breaks down less
Old Apr 6, 2008 | 01:38 AM
extralargenog's Avatar
Default Re: (importdude2000)
Royal Purple BLOWS Mobile 1 away..... I have first hand experience with a sloughof trouble that a simple swith to the purp took care of.
10-30.
Old Apr 6, 2008 | 09:16 AM
JoePSI's Avatar
Default Re: (extralargenog)
10w-40 Castrol GTX, change every two weeks (~750 miles). lol
Old Apr 6, 2008 | 10:43 AM
Default Re: (JoePSI)
anyone else use the 1300 tho?
Old Apr 6, 2008 | 12:45 PM
Danza's Avatar
Default Re: (Quad-Damage)
ive used diesel oils often when I can't get the amsoil I prefer (damn european car weights) and it's fine. I believe it will ruin/damage your catalytic converter if you have one
Old Apr 6, 2008 | 12:54 PM
SoCal EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importdude2000 &raquo;</TD></TR><TR><TD CLASS="quote">
breaks down less
lol. you mean viscosity?
OEM on my S4 is 5w30 i believe, and everyone who tunes or runs high hp or stage 3 advises mobil1 0w40. Less resistance at startup and high breakdown point.
Old Apr 6, 2008 | 12:56 PM
Default Re: (SoCal EJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoCal EJ1 &raquo;</TD></TR><TR><TD CLASS="quote">
OEM on my S4 is 5w30 i believe, and everyone who tunes or runs high hp or stage 3 advises mobil1 0w40. Less resistance at startup and high breakdown point.</TD></TR></TABLE>
haha yah!
Old Apr 6, 2008 | 01:10 PM
Danza's Avatar
oem is likely 5w40 like pretty much all vw/audis but its basically impossible to find routinely so 5w30 works
Old Apr 6, 2008 | 02:02 PM
Default Re: (Danza)
The oil is SAE 15W 40
Old Apr 6, 2008 | 02:07 PM
Danza's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quad-Damage &raquo;</TD></TR><TR><TD CLASS="quote">The oil is SAE 15W 40</TD></TR></TABLE>
right, i was just talking about his case. You can get synthetic diesel oils in a bunch of weights, i.e. 5w40 heavy duty synthetic for diesel trucks
Old Apr 6, 2008 | 02:09 PM
Default Re: (Danza)
So use this oil or what? I'm about to sell my car and i was going to change it for the new owner.
Old Apr 6, 2008 | 02:17 PM
Danza's Avatar
I have never owned a turbo honda, so I'm not a definitive source but...
I own a supercharged vw which I occasionally use synthetic diesel oil of equivalent weight with no ill effects yet.
Old Apr 7, 2008 | 01:09 PM
OMG B16's Avatar
I use Rotella 15-40
Old Apr 7, 2008 | 02:16 PM
stoopidfast's Avatar
I USE 1300 AND NO PROBLEMS IN BOTH OF MY CARS
DESIEL OIL IS GOOD FOR TURBO CARS BECAUSE IT HAS MORE DETURGENT IN IT AND IT HELPS WITH CLEANING
ricodemus
Feb 26, 2003 12:16 PM
CWBETB
Oct 7, 2001 09:08 PM
JM Performance
Sep 16, 2001 11:52 PM
