Earls/Aeroquip/Russel Banjo fittings....
Need the part number for any of the above for the HOND/ACURA fuel banjo fitting with bolt and the other end that attaches to the fuel rail. Don't need the complete kit as I will be making my own. Thanks
i know B&R make a fuel line kit with oem banjo fitting. Maybe they could get you the part number or just the parts that you need. Worth a shot i guess. here is the thread with pictures of the fitting:
http://www.hondamarketplace.co...39963
#2 = P/N 16680-PE7-661
#3 = P/N 16705-PD1-003
#29 = P/N 90008-PP4-E02
#30 = P/N 90009-PP4-E01
#33 = P/N 90428-PD6-003
#34 = P/N 90430-PD6-003
Or are you talking about a different part? Repost and I'll do my best to get the other numbers you're looking for.
i think he is going to be using stainless fuel lines so i don't think those fittings and parts will work.
he is looking for the end part at the end of the fuel line between #3 & #33 but exempt he needs that banjo fitting plus the part that connects that to the stainless fuel line.
Ohh.. I thought he was searchin for the OEM part number. getting a part number for just the end-piece of the hose is impossible, as it's sold as a complete fuel tube. So, going aftermarket as KENetics1 suggested, sounds about right. Sorry about the mixup
I believe you can use this fitting for both fuel rail and fuel filter. It's specific to the fuel rail but the fuel filter is also a 12mm bolt.
http://www.russellperformance....shtml
DESCRIPTION RED/BLUE BLACK
-6 AN Male Flare for Civics w/out Fuel Pressure Damper 640910* 640913*
-6 AN Male Flare for Civics/Integras with Fuel Pressure Damper 640920 640923
Here's a link from Summit: http://store.summitracing.com/...w=sku
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 »</TD></TR><TR><TD CLASS="quote">i'd contact B&R Fittings on here, he's got me all my parts super quick!</TD></TR></TABLE>
x2 that's what i suggested in my first reply
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KENetics1 »</TD></TR><TR><TD CLASS="quote">
x2 that's what i suggested in my first reply</TD></TR></TABLE>
often times the first response is the best
hannslebo
Jun 5, 2009 06:13 AM
R6Elmo
Oct 2, 2003 08:09 PM
