Ever Seen a Built Motor That Did NOT Smoke?
Old Jul 10, 2002 | 01:35 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Ever Seen a Built Motor That Did NOT Smoke?
Just like the title asks.
The reason I ask is because I personally have never seen a motor that has been "built" that didn't smoke.
I see posts all the time where people ask "buy swap X or build this motor, etc." and it makes me wonder if there are guys out there with built motors that don't smoke.
Old Jul 10, 2002 | 01:49 PM
Spade's Avatar
Default Re: Ever Seen a Built Motor That Did NOT Smoke? (B18C5-EH2)
As long as the person doesn't use a test pipe. Yes.
I have seen 3 built motors. 2 of which used test pipes....smoked.
the one that actually used a cat didn't.
Old Jul 10, 2002 | 02:09 PM
Mikey3000's Avatar
my built motor doesn't smoke anymore.
Old Jul 10, 2002 | 02:15 PM
sgT's Avatar
sgT
Default Re: Ever Seen a Built Motor That Did NOT Smoke? (Boss Hogg)
None of the motors I build smoke.
Old Jul 10, 2002 | 02:37 PM
DUCK COMMANDER's Avatar
Default Re: Ever Seen a Built Motor That Did NOT Smoke? (EVIL Teken)
Its all about how you seat the rings. I say seat them the way the car is goign to be driven, Fast and Hard.
Old Jul 10, 2002 | 02:57 PM
builthatch's Avatar
MiG-21 superfan
Default Re: Ever Seen a Built Motor That Did NOT Smoke? (JSutterEH2)
My y8 build, tht I built, does not smoke whatsoever, no cat, squeaky clean visually. My y7 build, however, did smoke a bit on full throttle; I suspect that had to do with the circus troupe that built it in Staten Island...
[Modified by builthatch, 6:59 PM 7/10/2002]
Old Jul 10, 2002 | 03:48 PM
non-VTEC's Avatar
my build smokes on rapid throttle snapping.
if you snap the throttle 3 or 4 times in a row really fast from idle up to about 5000rpm there is some blue smoke.........i'm pointing the finger at the poor PCV system............cant wait for my damn oil catch can......
Old Jul 10, 2002 | 03:52 PM
FSTASNTZ's Avatar
Default Re: Ever Seen a Built Motor That Did NOT Smoke? (non-VTEC)
My motor does not smoke.
Jason
Old Jul 10, 2002 | 04:35 PM
aeolus's Avatar
Default Re: Ever Seen a Built Motor That Did NOT Smoke? (FSTASNTZ)
now the ones who have built motors that dont smoke.....what kind of tolerances did u use?What size ring gaps?piston to wall clearances?Were the manufacture recommended specs used?just curious cuz im makin plans for a built block.
[Modified by aeolus, 1:36 AM 7/11/2002]
Old Jul 10, 2002 | 04:36 PM
sackdz's Avatar
Default Re: Ever Seen a Built Motor That Did NOT Smoke? (sgT)
Then why was there black chit all over your bumper @ teh expo!?
sack-who smokes mad-"unbuilt"
Old Jul 10, 2002 | 06:21 PM
builthatch's Avatar
MiG-21 superfan
Default Re: Ever Seen a Built Motor That Did NOT Smoke? (aeolus)
a major o consider is piston matrial selection...it is a fine science when running low silicon forged pistons to get the motor to have the proper piston-to-wall clearances; Consult the piston manufacturers and reputable shops...
Old Jul 10, 2002 | 07:44 PM
ninesecrx's Avatar
Default Re: Ever Seen a Built Motor That Did NOT Smoke? (builthatch)
The only thing my built motors smoke are the other guys who try to race me ...............Mike
Old Jul 10, 2002 | 09:56 PM
aeolus's Avatar
Default Re: Ever Seen a Built Motor That Did NOT Smoke? (ridge racer 2)
LOL!...hehehehe..You must be from southern california.I have a two CNC motorsports not to far from me.I never knew they did head porting....or tried to for the matter.
Old Jul 11, 2002 | 11:20 AM
sgT's Avatar
sgT
Default Re: Ever Seen a Built Motor That Did NOT Smoke? (sackdz)
Thats fuel silly. Thats supposed to be like that
Old Jul 11, 2002 | 11:24 AM
MikeSarr_GSR's Avatar
what kind of oils do you all run in those built engines?
I am finding that the Mobil1 likes to disappear...
its all good I can keep it fresh hehe
Old Jul 11, 2002 | 11:27 AM
sgT's Avatar
sgT
Default Re: Ever Seen a Built Motor That Did NOT Smoke? (MikeSarr_GSR)
castrol gtx 5 or 10w30
Old Jul 25, 2002 | 02:55 PM
shawnhayes's Avatar
Mine smokes a little at full throttle from launch. Why should I care Tom? Is it bad for the motor? Fill me in.
Shawn
Old Jul 25, 2002 | 05:19 PM
GruvyTune's Avatar
New User
I got about 45 miles on my newly built motor and now there is no smoking at all. I have a test pipe too.
running castrol gtx 10W30 and used wd40 to seat the piston rings as Earl suggested, rings seated in about 15 minutes that way!
Old Jul 25, 2002 | 08:28 PM
1 2 NV's Avatar
my built motor initially didnt smoke. that might have had something to do with the stock P72 ECU. now that i have a SKUNK2 ECU, it smokes. looks kinda black, but rings seal is great and compression is great. no cat for me and possibly the 9k shift points dont help either. i used castrol 30W for my 20 min break in then rodded the **** outta it after that. i have less than 1k on it still. will switch to castrol 5/30 next time.
Old Jul 25, 2002 | 10:37 PM
EpDarks's Avatar
Default Re: Ever Seen a Built Motor That Did NOT Smoke? (hondaatwsu)
Almost every "built" motor I've seen has smoked.
A lot of not "built" motors have smoked too.
Lsvsmoker
Sep 13, 2011 08:10 PM
g2turbo
Jul 31, 2006 12:59 PM
crispydee
Mar 24, 2005 10:46 AM
shermanyang
Aug 11, 2002 10:56 AM
