need help! running problems/wont start
Old Apr 4, 2008 | 02:44 PM
2wheelhunter's Avatar
Default need help! running problems/wont start
***UPDATE***
fixed it.. there was a loose ground wire one the thermostat to the wire harness!!! car runs great now! thanks everyone for your time and help!
-original post-
i have recently swapped in a jdm itr 97 spec motor into my 97 del sol si.. the engine starts up and idles fine. it drives fine with low throttle/low rpm driving, i can get on it full throttle and wind it out to about 6-8k rpm before it cuts out.. i'm not sure weather its fuel or spark. then once it cuts out once or twice it starts sputtering really bad and eventually stalls. it usually doesnt start up right away but just fire a little and stall out again.. i let it set for 20-30 mins or over night and it starts back up, runs and drives fine until i get on it, then the same thing happens
list of parts i've already checked:
spark plugs (new ngk vpowers)
new distributor (tried 2 different ones)
grounds to the engine
let me know if you have any suggestions!!!!
Modified by 2wheelhunter at 7:03 PM 4/6/2008
Old Apr 4, 2008 | 02:46 PM
MasterShake's Avatar
is vtec engaging? any CELs? low oil?
Old Apr 4, 2008 | 02:56 PM
Default Re: (MasterShake)
vtec does engage, no CEL, and i just changed and checked the oil-perfect
i should probably list a few other things.. its the stock del sol si wire harness for the engine, stock fuel pump, converted to obd1-chipped p28 (tested the ecu in another car and worked perfectly) stock fuel pressure
Old Apr 4, 2008 | 02:58 PM
Default Re: (2wheelhunter)
the engine may not be timed perfectly, i dont know how to time it because i changed the crank pulley and the new one doesnt have a mark on it for timing.
Old Apr 4, 2008 | 03:00 PM
lol oh ****, how sure are you that its set to TDC? id say go to a smog shop and pay the guy 10 bux to set your timing to stock, see if that helps.
oh and you may have a bad headgasket.
Old Apr 4, 2008 | 03:18 PM
i'm thinking it could be off from TDC because i put new cam gears on it.. i coulda sworn i had that set at TDC though, i started at the bottom up complelety redid.. i'll have to check that
Old Apr 4, 2008 | 03:20 PM
but check your headgasket with a compression test too, it could be letting coolant in the block
oh and compression test ran 230-235 across the board
Old Apr 4, 2008 | 03:21 PM
oh ok cool
unless it jumped a tooth?
Old Apr 4, 2008 | 03:22 PM
could have happened, see how loose the belt is.
Old Apr 4, 2008 | 04:18 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MasterShake &raquo;</TD></TR><TR><TD CLASS="quote">could have happened, see how loose the belt is.</TD></TR></TABLE>
could that cause this though?
Old Apr 4, 2008 | 04:27 PM
if it jumped a tooth
Old Apr 5, 2008 | 10:15 PM
checked timing tonite still 230-235psi across.. i checked the timing belt and still looked completely TDC....
I NEED HELP!!!!!!
Old Apr 5, 2008 | 10:27 PM
Former User's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2wheelhunter &raquo;</TD></TR><TR><TD CLASS="quote">checked timing tonite still 230-235psi across.. i checked the timing belt and still looked completely TDC... </TD></TR></TABLE>
Though the crankshaft pulley is missing timing marks, you must find some way to set the ignition timing to specification.
Old Apr 5, 2008 | 10:42 PM
Default Re: (RonJ@HT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RonJ@HT &raquo;</TD></TR><TR><TD CLASS="quote">
Though the crankshaft pulley is missing timing marks, you must find some way to set the ignition timing to specification.</TD></TR></TABLE>
i'm in the process of looking for a new harmonic balancer
would ignition timing cause this?
Old Apr 6, 2008 | 10:41 AM
ttt suggestions?
Old Apr 6, 2008 | 06:04 PM
liljukmoves
Sep 1, 2011 08:42 AM
j0keefe21
Engine Management and Tuning
10
Jan 2, 2009 02:08 PM
hondahatchgsr
Jan 30, 2007 12:11 PM
AlexT
Oct 13, 2004 05:45 PM
