I think I just got ripped off on this ECU - PICS
Old Apr 3, 2008 | 06:54 PM
Razr2's Avatar
Default I think I just got ripped off on this ECU - PICS
hfghgf
Modified by Razr2 at 4:52 PM 4/5/2008
Old Apr 3, 2008 | 06:57 PM
cherroneballs's Avatar
what kind of ecu is it? p28?
Old Apr 3, 2008 | 06:58 PM
Razr2's Avatar
Default Re: (cherroneballs)
Honest have no idea. The sticker is missing. It says "94 CU 4dr LX AT" on the front. So maybe a p06 converted to vtec? IDK
Old Apr 3, 2008 | 07:00 PM
n1_egsex's Avatar
* B A N N E D *
Default Re: (Razr2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Razr2 &raquo;</TD></TR><TR><TD CLASS="quote">Honest have no idea. The sticker is missing. It says "94 CU 4dr LX AT" on the front. So maybe a p06 converted to vtec? IDK</TD></TR></TABLE>
LX ecu isn't P28
Old Apr 3, 2008 | 07:04 PM
egsleepercivic's Avatar
search around the net and here I believe someone posted waht the number on the chip means, the one with 301 on it
gl
Old Apr 3, 2008 | 07:11 PM
nytosc's Avatar
From: New York in the summer, South Carolina in the winter
Default Re: I think I just got ripped off on this ECU - PICS (Razr2)
Its pretty shady how they removed all stickers on it- I can amost gaurentee that its a p06 converted over-
but anyways its fine as long as it was done properly
In the lower right corner, you can see where its chipped- so your good on that one
Now as for the automatic issue, and the vtec issue-
for the vtec issue check out this sight, find out what board you have, and follow instructions. If it looks like work was done in those areas, then your good to go
http://xenocron.com/install/index.htm
the auto issue shouldnt be bad either-
GL!
and any of the mods wana get rid of my trial status for me?
Old Apr 3, 2008 | 07:16 PM
.Grimace's Avatar
footwork mastery
Default Re: I think I just got ripped off on this ECU - PICS (nytosc)
yea it's chipped it just doesn't have the zif socket you're probably used to seeing. burn a b16 map and give it a whirl.
civicjoe's Avatar
I was just gonna link xenocron too!
Old Apr 3, 2008 | 07:17 PM
Razr2's Avatar
Default Re: I think I just got ripped off on this ECU - PICS (.Grimace)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Grimace &raquo;</TD></TR><TR><TD CLASS="quote">yea it's chipped it just doesn't have the zif socket you're probably used to seeing. burn a b16 map and give it a whirl.</TD></TR></TABLE>
Will it be okay without the "zif" socket? And for a new basemap do I need a new chip, or can it be done by just plugging into the comp and loading it on?
Old Apr 3, 2008 | 07:18 PM
slow_cx's Avatar
It is chipped. but i have no idea what ecu it is. You can find that out by looking up the number printed at the top of the circut board
Old Apr 3, 2008 | 07:29 PM
.Grimace's Avatar
footwork mastery
Will it be okay without the "zif" socket? And for a new basemap do I need a new chip, or can it be done by just plugging into the comp and loading it on?</TD></TR></TABLE>
yes it's fine without the zif socket it's just harder to get the chip in/out. you can reuse this chip you just need a cheap burner. xenocron sells them fo cheap like 65$ i think? or get a friend to do it.
jonrv13@
Oct 14, 2006 04:53 AM
JDMKid71
16
Feb 21, 2006 04:12 PM
the.hamburglar
Dec 27, 2005 07:24 PM
strebor95
Mar 3, 2005 03:42 PM
simplypinoyy
Dec 9, 2004 07:15 AM
