High-temp grease for clutch install?
Old Apr 2, 2008 | 01:30 PM
totsie7944's Avatar
Default High-temp grease for clutch install?
Hey guys, I am installing mynew clutch and flywheel tonight...I have ARP moly lube for the ARP bolts I got....where do I put the actual grease?
From my understanding, it goes on the inputshaft on transmission? Any pics of where it goes?
Can anyone confrim 76 ftlbs for flywheel and 19 ft lbs for clutch?
Old Apr 2, 2008 | 01:36 PM
RTW DC2R's Avatar
i never grease the shaft (lol) just the part in the clutch housing that the TO bearing moves on. and also grease the shift fork where it meets the TO bearing and the slave cyl. and also grease the inside of the TO bearing and on the flanges of the TO for the shift fork.
those torque specs sound about right.
make sure to align the whole assembly as perfect as you can with the alignment tool so its easier to get the tranny back on the block (input shaft into the clutch center).
Old Apr 2, 2008 | 01:40 PM
totsie7944's Avatar
Default Re: (RTW DC2R)
If I post a pic of the transmission tonight and clutch can you like put arrows on it showing where exactly you are talking about? lol...I get most of it, but I like pictures !
Old Apr 2, 2008 | 01:43 PM
RTW DC2R's Avatar
how could you even be attempting all this work without a helms? it tells you exactly where to grease and what the torque specs are. maybe someone else can help you with your little picture, Im busy tonight lol
Old Apr 2, 2008 | 01:56 PM
get RIGHT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2R &raquo;</TD></TR><TR><TD CLASS="quote">how could you even be attempting all this work without a helms? </TD></TR></TABLE>
That was my next question as well.
Old Apr 2, 2008 | 02:22 PM
Kenso's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2R &raquo;</TD></TR><TR><TD CLASS="quote">i never grease the shaft (lol) just the part in the clutch housing that the TO bearing moves on. </TD></TR></TABLE>
You actually should put a thin film of grease on the input shaft, in addition to the other spots you already noted.
Old Apr 2, 2008 | 02:36 PM
Dave-ROR's Avatar
Default Re: (Kenso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kenso &raquo;</TD></TR><TR><TD CLASS="quote">
You actually should put a thin film of grease on the input shaft, in addition to the other spots you already noted.</TD></TR></TABLE>
I've always done that as well.
Old Apr 2, 2008 | 02:44 PM
RTW DC2R's Avatar
i might put a little bit on the splines but thats about it.
Old Apr 2, 2008 | 03:33 PM
ITR.#1446's Avatar
here is a good place to download honda/acura manuals but you need to become a member first http://www.hondahookup.com/manuals/
MiNeSEK
19
May 11, 2013 12:05 AM
DFW
16
Feb 22, 2007 05:26 PM
Heinz57
16
Dec 29, 2005 07:00 PM
iwhichisme
Feb 28, 2002 04:42 PM
eh-D
Jan 8, 2002 02:50 PM
