ignition coil?
Old Apr 1, 2008 | 11:01 PM
obuhmyuh's Avatar
Default ignition coil?
ive been having a problem with my car bucking lately at about 2500 rpms and other misc. parts of my power band. but today when i was on my way to work it bucked violently and my tach went ape **** and my car turned off and was hesitant to turn back on (luckily it did). but what could cause this, i was thinking dizzy or a part of the dizzy assembly (igntion coil, rotor cap, etc.), i was also thinking an o2 sensor since my car is running rich.
d15b jdm sohc VTEC - only CEL is code 21 VTEC spool solenoid (not related)
Old Apr 2, 2008 | 01:05 AM
baulum's Avatar
Possible your ignition coil
Old Apr 2, 2008 | 12:40 PM
obuhmyuh's Avatar
Default Re: (baulum)
would there be physical evidence that it's damaged?
Old Apr 3, 2008 | 11:48 PM
93dx757's Avatar
im experiencing the same problem right now with my jdm zc sohc vtec and i was thinking about the ignition coil as well. im towing it to the shop tommorow and im gonna give it a try. did ur speedometer come in and out when ur tach went crazy?, mine did lol. let me know how things go for ya, ill be sure to do the same
Old Apr 4, 2008 | 11:38 PM
obuhmyuh's Avatar
Default Re: (93dx757)
ya know im not sure, but probably. my car broke down on the freeway today but i think it was a VTEC controller ~ ecu error resulting in several blown fuses, controller is coming out tomorrow to eliminate that as a possibility.
please, no one chime in about me using a VTEC controller, unless you've owned one and done some homework on it.
Old May 18, 2008 | 09:02 PM
obuhmyuh's Avatar
Default Re: (obuhmyuh)
bump
bucking went away, but now my tach goes nuts every once in a while and my motor misfires.
Old May 19, 2008 | 01:21 AM
cjk95delsolsi's Avatar
it sounds as if it is your ignitor which is located in your distributor. It runs about $100 for this part, the cheapest route would be to replace your whole dizzy for about $150 in case you have other issues with your coil or other wiring in your dizzy.
stivic
Feb 14, 2006 03:55 PM
Speedz
Oct 26, 2005 03:36 PM
96b18c
Dec 28, 2004 11:31 AM
quarterkorean
10
Apr 19, 2004 05:48 AM
Confuc1ous
Aug 23, 2003 11:17 PM
