93 ls passenger window issue
Old Apr 1, 2008 | 11:16 AM
tttturok2001's Avatar
Default 93 ls passenger window issue
ok, so my passenger window wont go down from either switch(driver or passenger) the saftey locking feature is not engaged. so i took the panels off and tested the wires. what ive found is that if i put 12v's to the wires i can make the window go up and down. so i figure that the motor is not broken sense when electricity is put to it, it works.
so is this my switch? a regulator? or what?
Old Apr 1, 2008 | 11:27 AM
HONDRETTI's Avatar
Default Re: 93 ls passenger window issue (tttturok2001)
your motor is lacking juice, hence when you add power it speeds up. my DA passenger side window wouldnt work sometimes.... figured it just needed a new motor.
Old Apr 1, 2008 | 01:11 PM
right, i dont think its lacking juice, i just dont think its getting ANY at all. i was wondering why its not getting any, is it the door switches? is it the regulators? why is the motor not getting power?
Old Apr 1, 2008 | 03:58 PM
bump for info on switch or regulator?
Pauly321
Dec 2, 2016 12:15 PM
02EX
Jun 1, 2015 04:25 PM
einzelherz
Dec 16, 2011 02:58 PM
marshun
May 21, 2007 10:11 PM
staticrex
Sep 19, 2005 11:30 AM
