Autometer shiftlight wire in with factory tachometer?
Just wondering if anybody else here has ever attempted wiring in an aftermarket shift light to work in conjunction with the factory tachometer?
I have a 94' CX Hatchback, in which I picked up a cluster out of an EX 5-speed car (factory tachometer gauge cluster) and instead of one of those big *** shiftlights that normally come with the 5'' Autometer tach, I want to use one of those writing pen sized shiftlights, so that i might be able to hide it in one of my A/C vents or something.....
Question being, is there anyway I can get this aftermarket shiftlight to work with my factory gauge cluster? If so, HOW????
Thanks,
-Ant-
Thanks,
-Ant-
Yes, wire it up the same way as you would with an aftermarket tach. The wires can be wired into the cluster harness.
Shift Light Wire ---> Cluster Harness Wire
1. Green (tach signal) ---> Blue
2. Red (12v) ---> Black/Yellow
3. Ground ---> dash bolt or Black
I didn't know you could plug those chips into the smaller shift lights....
I'm talking about one of the shift lights that might be as big around as a sharpie marker.....
summit makes an rpm activated switch, thats what i used. I think its like 40 bucks and you don't need to buy any "pills" you can adjust it in 100rpm increments, i think it will adjust up to 10k
Does the number of cylinders really matter?
Because on the page, it specifies that it's calibrated for a V-8 engine....
Thanks for the link BTW....
