i have serious vtec problems... =/
Old Mar 31, 2008 | 09:24 PM
philivtec's Avatar
Default i have serious vtec problems... =/
ok so i just got done swapping a gsr set up into my car, got everything running good, but now run into the fact that my vtec does not crack, does not engage at all. i thought there was something wrong with my ecu so i plugged it into my friends car and it worked fine, then i tested to see if my vtec selenoid worked and it also did. so my final conclusion is that i need a "knock sensor" and have no idea where i can get one for cheap. and also does it matter that i have it obd1?
Old Mar 31, 2008 | 09:27 PM
crazyguy's Avatar
Default Re: i have serious vtec problems... =/ (philivtec)
what kind of ecu are u running and yes u do need a knock sensor, without it. vtec wont pop. u can find it from ebay. local junk yards..ect or u can even try to bypass it.
Old Mar 31, 2008 | 09:37 PM
philivtec's Avatar
Default Re: i have serious vtec problems... =/ (crazyguy)
i am running the stock p72
how much will the knock sensor go for?
kinda low on cash
Old Mar 31, 2008 | 11:26 PM
Jason-'s Avatar
Junk yard it.. But its going to be a pain in the *** to get out. And don't tell them you want that part, cause they most likely wont sell it to you.
-Jason
be18see1
Oct 13, 2007 12:02 PM
be18see1
Aug 17, 2007 08:14 PM
3.504
Oct 4, 2005 11:26 AM
stubk20
Jul 6, 2004 11:59 PM
22civic
Jun 21, 2002 04:45 PM
