vtec wiring problem on an ls/vtec
Old Oct 3, 2005 | 08:53 AM
3.504's Avatar
Default vtec wiring problem on an ls/vtec
i just installed an LS/vtec into a 99 dc4
the engine runs great, still in the break in process but its time to wire vtec in.
the car has an obd2-obd1 conversion harness and using a stock obd1 p72 ecu
i have the vtec sol. wired into pin a4 on the ecu and the oil pres. switch wired into pin d6. the ls block doesn't have a knock sensor, and i dont have a knock sensor wired into the ecu.
the solenoid tests good and works (i wired it to a fused switch just to make sure it engaged.)
there is a memory fault code 14, IAC fault. it wont set off the CEL, but it sits in memory.
i can't get vtec to activate using the ecu, i need advise on how to get vtec to activate using the ecu.
thank you
Old Oct 3, 2005 | 09:36 AM
Korch94's Avatar
Default Re: vtec wiring problem on an ls/vtec (3.504)
there is a place on the back of the block to drill and tap a hole to add a knock sensor......... while this does not explain your problem with not having vtec..... a lack of a knock sensor signal will cause the ecu to retard timing (loss of hp)
check your connections again, also try a different vtec ecu if a friend has one that you can borrow.
as long as you connected those 2 wires correctly like u said then there should be no problem
Old Oct 4, 2005 | 11:26 AM
3.504's Avatar
Default Re: vtec wiring problem on an ls/vtec (Korch94)
i found the problem, it was the p72 looking for a knock sensor.
i plugged in a chipped p28 and it clicked vtec w/ my wiring all in the same positions.
the p72 was a borrowed ecu to just get the car running (because i was having problems with getting it running correctly and its untuned).
now i guess i'll run the p28, w/ no knock sensor (cause i dont want to buy one)
thanks for the help
civic_si_101
Oct 21, 2008 12:44 AM
Murse
Sep 22, 2006 12:37 PM
brian3676
Dec 21, 2005 04:32 PM
Ibanez
Sep 2, 2005 11:57 AM
