how do i bleed my clutch line?
Buy a bleeder kit or make one out of 25 cent/ft Lowes clear tubing like me.
Fill with Dot3 to the top (make sure not to run it dry again, or you'll just have messed up everything you tried to do), crack open the slave bleeder and attach the tubing, slowly pump the brakes 6-7 times, top off with more Dot 3, pump again 6-7 times and on the final pump hold down the pedal (you can rig something to hold it down for you [I used a random length of wood against the seat]), tighten up the bleeder screw.
Test 'er out! GL
Test 'er out! GL
ja20_eg
Sep 17, 2012 03:54 PM
