P2T ECU instead of a P72.
Old Mar 31, 2008 | 12:34 AM
djviet2000's Avatar
Default P2T ECU instead of a P72.
i was being bored today and i was scrubbin the interior down. and i took the ecu out and i was like...wtf a P2T ecu. i thought a B18C is a P72. so i thought i had a OB1 ECU. i went inside and i did a search...its a 99-00 Si ecu. great. the people who did my swap jacked my ecu or something. so i i have a to get a OB2B P72. the question is...is there a different from the OB2A and OB2B ecus? i know my harness is meant for a OB2B (99 Civic). my motor is a 98. will there be any problems?
Old Mar 31, 2008 | 12:53 AM
BlueIntegraBoy's Avatar
Default Re: P2T ECU instead of a P72. (djviet2000)
You need the OBD2B ECU because of the ECU plugs. But OBD2B P72s have immobilizers that you will have to remove (which I know of a writeup). You can always use an OBD1 or OBD2A P72 if you get a jumper harness.
Old Mar 31, 2008 | 01:04 AM
djviet2000's Avatar
Default Re: P2T ECU instead of a P72. (BlueIntegraBoy)
is it hard to remove the immobilzer? the obd2b to obd2a harness how much they usually run for.
Old Mar 31, 2008 | 01:07 AM
Not sure how much the jumper harnesses run for. Immobilizer removal is quite simple with a soldering iron.
Old Mar 31, 2008 | 01:13 AM
djviet2000's Avatar
i tried to do a search on yahoo for a ob2b to ob2a harness...nothing came up =/ i hope the Si ecu wont mess up my motor.
Old Mar 31, 2008 | 01:21 AM
Search Honda Jumper Harness
The P2T can do some harm since it is supposed to run a 1.6L engine. You'll run a little lean.
Old Mar 31, 2008 | 01:27 AM
djviet2000's Avatar
yess i found it. i really apreciate it man.
jdmjunior1991
Mar 11, 2014 05:19 AM
Motivated_EK
Jun 18, 2011 09:50 PM
BrandonB16
Feb 17, 2009 05:33 AM
